This is well overdue, but I need to start working on headsets at home instead of relying on LBS. Issue I have is that one bike has a 1.5'' headset and I want to find a removal tool and headset press that will work on all bikes. Any help appreciated.
Cyclus headset press but you'll need two sets of fittings. I bought a set of extra 'plates' (about 3 extra pairs) off someone on here that basically means mine fits all headsets and most PF BB's
You need a crown fittign tool - most will do 1", 1/18" and 1.5".
Also the removal tool - if you buy a proper one you can splay a 1 1/8" one out a bit to fit a 1.5" headtube but the right tool makes it a safer job with a carbon head tube.
Crowbar/large screwdriver for removal
Threaded bar with various size washers for installation- i use cut up inner tubes to protect the headset during installation- from marks not actual damage [ or hammer and blocks of wood]
Not sure on how much an engineered solution costs but a lot considering how easy it is to make something
I think you can buy pipe and then slice and flare them as removal tools as that is all the removal tool is anyway
I find an old socket set with long bar on works really well, plus hammer.
I have so far only ever installed headsets using a couple of blocks of wood, a second pair of hands to line it all up/hold still, and the Yorkshire screwdriver again. So far, its always gone in straight and simply (apart from one H/S that was long enough on the insert to make contact with a lump in the drainage/tube joint inside the headtube)
Old handlebar chopped in 2 works for me, upgrading to 35mm would make it even betterer
