Are the actual brakepads that you get in the Uberbike finned pads set the same as the normal non-finned brake pads?
I ask because there's some finned ones on ebay that work out cheaper than the regular ones, I don't really care about using the fins as my brakes work fine, so I wondered if I could use them like regular pads.
I'm thinking perhaps there's less pad material so the finned part can fit in the caliper, although I've never used finned pads so dunno... If that's the case I'll just spend a few extra quid and get the normal ones.
Thanks for reading this thrilling question!
I think that the backing plate is thinner on the finned ones, so the overall thickness will be less (even though the pad material thickness will be the same).
OK thanks makes sense, thanks I'll buy the regular ones.
Yep, he's right, the backing plate is thinner.
Much less "pad" material...
And , TBH, a little bit shit
Still with normal ones unless you are riding 10/10th all the time
