Tyre Sealant
[Closed] Tyre Sealant
[#348540]
I have decided that rather than going tubeless I'm basically going to change from using Presta to Schraeder tubes so I can remove the core's and dump some sealant inside (my wheels can take either with an adapter).
Anyway, some questions:
What are your recomendations for sealant, I was planning to use Stans?
If I dont use the bike frequently enough will the sealant congeal into one big gloopy mess and not flow through the tube enough to prevent punctures?
do I need to keep spinning the wheels (i.e. using the bike) regularly? I currently use the bike once or twice a week at most as I run more through winter but the balance evens out as the nights get lighter and warmer.
How long does it take the sealant to dry up and become useless?
Posted : 27/02/2009 9:43 pm
A Few things...
Schwable make presta tubes with removable cores...
Secondly when the sealant dries inside the tube - how will you get it out ? You'll add about 50 grams per wheel with sealant. When i dries you replace it so your wheels will get heavier and heavier.
Sealant life varies - JRA Wheelmilk i found poor - it dried solid within 3 weeks. Stans lasts longer though.
Posted : 27/02/2009 10:06 pm
All other mountain bikes in the house have car type valves, so it makes sense that I convert the only MTB that isn't schraeder so I can use the same spares when out and about.
My plan is to find a sealent that will last 6 months or so with minor topping up and replace the tubes away after that, as I do more running than cycling over the winter anyway.
Amongst other things, I was concerned that if I go tubeless and it dries out its a pain to clean and reseal the tyre, with tubes and sealent if it dries I just rip out the tube and start again with no mess, and also trailside tube changes should be a bit cleaner if they're ever necessary..
Posted : 27/02/2009 10:30 pm
I've had the best luck with Stans in a UST tyre.Just had a wheel rebuilt and pulled the tyre off.Still sealant sloshing around in there from last April!
Thanx Max
Posted : 27/02/2009 10:52 pm
Max,
How much did you put in, have you topped it up at all, and how often has the bike been ridden.
I am wondering if theres more chance of the sealant going off if the bike is stationary for long periods
Posted : 27/02/2009 11:03 pm
