Tyre repair patch
[Closed] Tyre repair patch
[#4638569]
Anyone know of a tyre repair kit available for when you split the sidewall of a tyre? Wondered if there's a purpose made patch available or do we just use multiple inner tube patches?
Posted : 10/12/2012 3:20 pm
Depends how big the split is. You could try a tubeless tyre repair kit
Posted : 10/12/2012 3:31 pm
wrong thread 🙁
Posted : 10/12/2012 3:33 pm
Park tyre boot
http://www.wiggle.co.uk/park-tools-emergency-tyre-boot-patch/
Posted : 10/12/2012 3:44 pm
If you want a cheap option on the trail then an old toothpaste tube will do as well any sort of flexible yet tough plastic.
Posted : 10/12/2012 3:46 pm
Some very cheap puncture fixing kits still have a piece of 'tarred' canvas which is intended as a tyre patch. Use the (flammable) glue on both tyre and patch, leave to dry, glue again and leave to dry, then attach. Dust around it with chalk and the job is a good one.
Inside of tyre wall must be clean and dry before you glue it.
I have had poor results with non-flammable glue.
PaulD
Posted : 10/12/2012 4:13 pm
A couple of layers of this as big as you need. If the split is big/gaping then stitch and glue as required. Superglue is fine on the outside and use normal vulcanising solution on the inside. Works a treat for me and I regularly slice sidewalls 🙄 .
Posted : 10/12/2012 4:23 pm
Lezyne "Smart Kit" is £3 and comes with 6 adhesive tube patches and 1 tyre boot.
Posted : 10/12/2012 9:20 pm
The Park kit is very poor value as the patches are just not sticky enough.I used an energy gel wrapper on a road bike in the Alps to get me back,then stuck on a new tyre.Any piece of tough flexible plastic will do the job of a patch kit.
Posted : 10/12/2012 9:47 pm
