idiotdogbrain - Member
What are people using to measure pressure? Recently bought the Topeak D2 gauge as I thought now that I'm running tubeless it'd be good to be able to accurately repeat pressures from pump to pump. Thought I was running around 30F/34R; turns out my preferred pressure is 21F/24R! That's Maxxis EXO 2.35 on 30mm internal rims, 160/145 FS, 14st (kitted up) rider.POSTED 8 HOURS AGO #
I've just picked up the Topeak D2 as well. Used it for the first time last night and was a bit surprised. I weigh about 90kg kitted up with a full 3l pack etc. I always just used my Joe Blow track pump and stuck 30psi in previously. The D2 measured this at 20psi - I was actually going to start a thread this morning about the accuracy of the D2. My tyres feel quite firm and surprised they only read at 20psi.
So what are peoples thought on accuracy?
having ridden my FS for the past few weeks (Anthem with 650B carbon rims, Nobby Nic 2.25) and 24/27 I was on the Soul 26'er last night, with 2.3 Purg's and Mavic 719's. I found rear at 27 was banging on the roots a lot, so a wee pump up to 30 and it was much better. I am just over 12 stone.
I've a couple of pressure meters (different manufacturers) and they are reasonably consistent between them and also consistently lower than the gauge on the track pump.
So long as the gauge is consistent over time I'd just inflate to whatever pressure you are happy with and use that, the actual number isn't that important.
Rarely measure them just squeeze/prod
For me thin tyres work over a wide range of pressures
The fat tyres are more sensitive to temperature
