Tyre pressure gauge...
[Closed] Tyre pressure gauges?
[#7552255]
Any recommendations for something reliable for Presta valves?
Posted : 03/01/2016 11:27 am
http://www.topeak.com/products/pumps/smartgauge_d2
Posted : 03/01/2016 11:29 am
 igm
Halfords do an own brand one at £15ish that works well enough.
Check the range of pressures you need - fat at 5psi or roadie at 120+psi?
Posted : 03/01/2016 11:45 am
Halfords own brand track pump, Topeak Joe Blow track pump, Fox shock pump (for shocks obviously), all been reliable.
None of them show the same pressure, but that's not important. So long as each time I use the same pump I hit the same mark, that's all that matters.
Also... fingers. Most reliable gauge, portable and lasts a lifetime (until you get arthritis).
Posted : 03/01/2016 12:01 pm
http://singletrackworld.com/reviews/review-sks-airboy-xl-pump-and-airchecker-pressure-gauge/
Been thinking about this gauge tested recently by STW, not that I [i]need [/i]it... but when has that stopped me before!
Posted : 03/01/2016 12:15 pm
+1 for top peak d2 really good and accurate
Posted : 03/01/2016 1:01 pm
I use the d2 and am really pleased with it.
Posted : 03/01/2016 1:02 pm
So how do I use a Topeak D2 with slime filled tubes and tubeless tyres... 😳
Posted : 03/01/2016 4:17 pm
Just the same as with any other tyre - not had a problem with mine. If you've just added fluid then drain the valve by rotating it to the bottom of the wheel.
Posted : 03/01/2016 4:27 pm
+1 for top peak d2 really good and [b]accurate[/b]
how do you know?
I have a BBB digital gauge, and it is more [i]precise[/i] than the analogue gauge on my cheap Airace track pump, but they both give similar pressures. Whether they are accurate or similarly inaccurate I have no idea as I've never had them calibrated.
Posted : 03/01/2016 4:36 pm
I bought a topeak d2 digital guage just before Christmas.. I'm on Presta valves and I'm pleased with it.
I suppose it doesn't lock onto the valve like a track pump does so you have to hold it on the valve, but other than that it seems great, well built, easy to use. Seems like a solid bit of kit that should last a long time.
Posted : 03/01/2016 4:58 pm
As deadkenny mentioned.. It's not so much that it's perfectly calibrated (although I've no reason do doubt it's too far out).. They key thing is to have a reliable repeatable reading so you can use it as a baseline to fine tune from.
Posted : 03/01/2016 5:02 pm
Aye, consistency is important, accuracy isn't- who cares what your tyre pressure actually is? But if you've got more than one pump that can still be an issue, my joe blow used to read about 10psi higher than my airtower at 20psi (they both read the same at 100psi...)
The topeak gauge is good though- most useful is its adjustment mode, not all gauges will do that so you have to check pressure, reset, remove air, check pressure again. But it realtime adjusts which is handy. And it releases a decent amount of air while you do it unlike accugages.
Posted : 03/01/2016 5:31 pm
 JoeG
Schwalbe +1
Posted : 03/01/2016 7:30 pm
I almost bought the schwalbe one.. But general online reviews seem to favour the d2.
Posted : 03/01/2016 7:48 pm
