Are there any other options apart from Topeaks SmartGauge?
Using a SKS digital which does the job
[url= http://www.jensonusa.com/!1-LfxIKwy1Zg8m264eMcSQ!/Meiser-Accu-Gage-Dial-Pressure-Gauge?utm_source=FRGLUK&utm_medium=organic&cu=GBP&pt_source=googleads&pt_medium=cpc&pt_campaign=&pt_keyword=&gclid=CKKVx-62htICFQcz0wodhXMA8w ]the daddy....[/url]
Wouldn't recommend carrying it around the trail but this is great for keeping at home/in the van. Gets good reviews. Will only fit a schraeder valve though so you will need one of the adapters for presta valves.
Much, much larger than actual size if viewed on a PC. May be close to actual size when viewed on a phone. 😀
[url= https://www.amazon.com/Schwalbe-Airmax-Digital-Pressure-Gauge/dp/B0025TYV7M ]https://www.amazon.com/Schwalbe-Airmax-Digital-Pressure-Gauge/dp/B0025TYV7M[/url]
Edit - Or maybe I should blame the new improved forum! 😆
Nobeerinthefridge - Member
the daddy....
Would have to agree 🙂
Can you get those accugage jobs somewhere that isn't Jenson? Is there a uk source?
kayak23 - Member
You can pick them up on eBay but even then they ship from the states. Worth the wait though imo 🙂
I'm going to agree. It is worth the wait. I got mine via eBay as oink1 mentions.
I'd go digital over analogue any day.
I use a Oxford one as it's +-. 5psi. Most are +-2
Fingers.
Give tyres a squeeze, feels right, good to go. Bit soft, pump up.
