Tyre clearance on a...
[Closed] Tyre clearance on a Genesis Equilibrium
 wors
[#9389351]
Anyone know what the maximum size tyre will fit in?
Posted : 19/06/2017 12:18 pm
i have the older rim braked version. (pre 2015 i think)
can fit a specialized 33c tyre in. no clearence for guards but rideable.
Posted : 19/06/2017 12:21 pm
rim brake or disc version?
The rim brake version (well 4 year old version but still same I think) will take a 'small 32mm' without guards, or a 'big 25mm' with them, and everything in between is a case of it depends on exactly which tyre/rim and guards you have fitted. ie: you might get a 28mm under guards, you might not, it depends.
No idea about the Disc version though...
Posted : 19/06/2017 12:22 pm
My rim brake 853 version from 2013 with guards will fit 28mm conti GP4000 front but only 25mm rear (sks chromoplastics). I reckon 32mm would be max without.
Posted : 19/06/2017 1:59 pm
My 2017 rim brake version is quite happy with 28s and mudguards. There's a bit of room to spare as well.
Posted : 19/06/2017 2:45 pm
My disc version has 27s and SKS guards with a little room to spare.
Posted : 19/06/2017 7:21 pm
2016 725 disc. 28mm Duranos and Chromoplastics. You'd get more without the guards. 30...33 maybe. I reckon any significant movement in the wheel could rub the fork after that. Big clearance for more on the rear.
Posted : 19/06/2017 9:43 pm
