Tyre advice. Spesh ...
[Closed] Tyre advice. Spesh butcher/purgatory
[#4954097]
Basically... I got a good deal on a pair of 2.3 butcher control's and I already have a pair of the newer 2.3 purgatory control's on there at the minute.
Riding is all mountain/aggressive xc on a 2010 stumpy elite as much up as down in typical uk muddy conditions.
I've read that butcher front purgatory rear is a good combo... In this weather would butcher front and rear be better, putting a purgatory on the back when(or if) it dries up...
Happy enough with the purgatory... There certainly better than the old purg 2.2's just a little lacking in outright grip at times but they roll fast for the grip... Assuming the butchers will stick better but be harder work up the hills.. Anyone running this combo?
Just to confirm... This is the butcher control 2.3 2 bliss.. Not the dh butcher. And I do run tubeless.
Posted : 12/03/2013 6:39 pm
Not sure what the difference is, but I've got the 2.2 Purgatorys F+R and really rate them for mixed/muddy conditions (i.e. everything outside of a propper summer).
Posted : 12/03/2013 6:44 pm
I run a butcher front/purgatory rear and its a great combo - on real loose climbs I sometimes wish for something that digs in a bit more than the purg but on the whole I like it a lot as a rear reasonably fast rolling tyre, have thought about a butcher rear too and next winter I'll prob stick one on.
Posted : 12/03/2013 7:22 pm
What do you like more about the new 2.3 Purgatory? Just interested, as the 2.2s are my fave local mixed/wet conditions tyre at the moment. Size looks about the same despite 2.2>2.3 labels.
Posted : 12/03/2013 7:31 pm
The 2.3's just seem to grip slightly better and roll slightly faster. Not a world away... But an improvement!
I've mounted the front butcher tonight. Undecided wether to put the other on the rear for a bit or leave the purg on...
Posted : 12/03/2013 7:42 pm
ta.
Posted : 12/03/2013 7:44 pm
Just put a Butcher control on the front - was running a Minion 2.3 Exxo.
First impressions are that the compound is lots softer and also the volume is nearer a Maxxis 2.5, but weight is actually lower than the Minion, without really sacrificing sidewall thickness.
Only had a very fast blast last night, but seems damn good and lots grippier.....
Posted : 12/03/2013 8:10 pm
What do you run in the rear andyrm?
Posted : 12/03/2013 8:13 pm
How much were the butchers?
Posted : 12/03/2013 9:25 pm
Under 50 quid for a pair, 20% off for getting 2 so I thought I'd get the pair even if I decide to keep the purg on the back...
Posted : 13/03/2013 4:02 pm
Haven't used the Purg but the Butcher's a fantastic tyre- just a better Minion, really. Grips not [i]quite[/i] as well as a 2.5 Supertacky, especially on hardpack and slimy rock, but clears mud better, rolls like a 2.35 Maxxpro (and Specialized know how to work a ruler, so their 2.3 measures almost bang on 2.3, making it the same size as a "2.5" maxxis)
I've been using a pair recently and it's slower than I like for trailcentre stuff where that much tyre is really just overkill, but it's well worth it on dh and evil offpiste stuff.
Posted : 13/03/2013 4:35 pm
