Turner flux sizing?
[Closed] Turner flux sizing?
[#1861781]
looking at the specs on the turner site I'm tright on the cusp of small and medium @ 5'7" (on a good day!). The small has a slightly shorter TT and the medium a slightly longer TT than my current Kona Kula (17" - I think) hard tail. Although we are only talking 1/2" either way.
Anyone else been in between sizes and what did you go for?
Posted : 04/08/2010 2:47 pm
If I was you, I'd probably go Medium and put on a short stem if you are used to a 17" Kula. But then, I wouldn't get something that expensive without a test ride.
Posted : 04/08/2010 3:14 pm
I'm on the cusp of a medium/large. I have a lot of seatpost showing on mine and it does feel a bit small at times - certainly compared to my race hardtail. I'd also be inclined to go for the larger size and run a shorter stem.
Posted : 04/08/2010 3:21 pm
Medium I would of thought.
Best to check in person though to confirm before spending out that kind of money imo.
Posted : 04/08/2010 3:22 pm
damn right I'll want to try one first! I'm guessing it is going to be a lot easier to find a medium to test than a small. I'll certainly be able to know if it feels too big and a stem is obviously a quick, easy item to change on a test ride.
Posted : 04/08/2010 3:30 pm
I am 5ft 10 and ride a medium with a 110mm stem and riser and straight seatpost. Had an 18inch Kona before.
If you are around the Surrey Hills or Swinley you could try mine - finding a demo might not be so easy, most demos are 5-spots it seems.
Bought my frame without trying it 🙂 Only tried a 5-spot.
Love it though 🙂
Posted : 05/08/2010 5:19 pm
remember reading to go for a bigger size as it will have a longer wheelbase and thus be more stable.
Posted : 05/08/2010 5:34 pm
You'd definitely be fine on a medium. I'm more "small" than "medium" on most bikes but the Turner and Intense are fine as a medium.
Posted : 05/08/2010 6:25 pm
thanks Andrew. I am around Guildford, so when I finally find the readies I'll drop you a mail, it would be great to try one for size.
thanks all, looks like a medium might be the way to go.
Posted : 06/08/2010 10:52 am
Andrew - if this offer still stands could you please drop me a mail (address is in my profile).
Posted : 17/02/2011 10:26 am
sent...
Posted : 17/02/2011 11:02 am
