can I ask what people are running- is it more popular to run 120mm, has anyone done both? Thanks in advance
Mrs NBT has been running rebas at 100mm. Have just increased the travel to 115mm (they're 2007 model so later models go 100-120). FIrst ride on longer travel forks should be this sunday....
I've got some 120 reba uturns
RS SID RLT Ti 120mm, 15mm axle on mine. RS Reba Race 120mm QR on ar lasses.
Fox F120 on mine. Sorted.
yes I was thinking of a f120 due to superb reliability Ive had in last 7 years of fox forks- I could always have spacers added if I change my mind
Pace RC39's on an '09 DW Flux. Absolutely spot on from my point of view but will probably replace with 120mm forks when they finally die.
120mm for certain. Personally I prefer rockshox, so I've got SIDs on my flux.
Hi
I run Rockshox Revs U-turn on mine mostly as I already had them.
Set on 120mm most of the time but have wound them out to 140mm for extended downs eg Garburn Pass, Whinlatter etc.
I know I probably shouldn't but there you go-it's awesome.
Have been thinking on some Fox 120 but not sue its worth the expense
Steve
