As above, i'm after a bush kit for 2005 Turner 5 spot with Pushed Rocker 5.75'" travel. How much and where from?
Nick
Silverfish I'd guess.
just noticed chain reaction are selling them
I got mine from sideways cycles last time, mail order.. was bloody expensive though.. doller against pound and all that, was about £80 I think.. quite a lot for some bits of metal and plastic. Thank god I don't have to change them that often!
You could also try the Turner website direct, Silverfish as mentioned and High Peak Cycles used to do Turner don't know if they still do
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=51772 ]Turner bushings here[/url]
last time a mate and I got a set each on one order from turner direct and shared the shipping, which worked at at 75 quid each for all pivots.
I got mine from wheels at staveley - 80 squid.
One guy had all his bushings replaced with normal bearings at our place. The whole lot was machined and then bearings fitted. No idea how successful the conversion was but I'll see if I can get any info when I go back into work tomorrow.
Considering the regularity withwhich you need to change them may as well pay the money and replace as per spec. Value really is pretty good!
Lost count of the number of shock bushes replaced at £20 a pop on the Superlight.
