turbos and tyre cho...
[Closed] turbos and tyre choice
[#5822799]
Have recently bought a turbo (thanks halfords) - using my CX bike with nobbly tyres and its quite noisy. If I were to get some turbo specific tyres would that reduce the noise? £25ish from crc
thanks
Posted : 04/01/2014 1:42 pm
Any smooth tyre will reduce noise. Turbo tyres will help a bit more and save you putting a flat spot on your proper tyres.
Posted : 04/01/2014 1:44 pm
And as my mrs has found out... That flat spot appears in a 1 hour session on soft race tires.
Posted : 04/01/2014 2:10 pm
I use an old worn down road tyre, no tread left on it for road use, but seems fine for turbo duties
Posted : 04/01/2014 2:13 pm
 Jase
For years I used normal road tyres but recently got a specific turbo tyre, can't say I've noticed any difference.
Posted : 04/01/2014 2:17 pm
No massive difference noise wise as far as I can tell, but doesn't slip as easily or wear anywhere near as fast.
Posted : 04/01/2014 2:43 pm
Find turbo specific tyres a lot better for not leaving bits of rubber all over the turbo and whatever happens to be behind the turbo.
Posted : 04/01/2014 3:02 pm
DC Rainmaker had a review/comment on them, found them actualy noisier and went back to just using last seasons worn out tyres.
Cant say I noticed any difference between £30 turbo tyres and £10 schwalbe blizzards.
Posted : 04/01/2014 3:13 pm
Marko, I have an as new Tacx turbo trainer tyre in 700c. I'll take £15 posted if you're interested.
Posted : 04/01/2014 4:16 pm
