Tubs - Glue or Tape...
[Closed] Tubs - Glue or Tape?
[#4028841]
I just bought a set of used Zipp wheels with Tubs. I need to get a spoke changed on the back wheel so I will need to reattach the tub when I am done.
Given that I'll be road racing on them, I was 99% certain that I would go with glue, but oddly, I can't see any at CRC. (do they sell it?)
Any good or bad experiences with tape?
Posted : 01/06/2012 12:14 pm
Never used tub tape as I prefer to trowel on the cement. 🙄
I think Evans may be the cheapest at the mo - http://www.evanscycles.com/products/continental/rim-cement-350g-ec011799?query=tub%20cement
Posted : 01/06/2012 12:18 pm
This
http://www.wiggle.co.uk/tufo-tub-tape-for-road-wheels/
Unless your using them on track, then glue them
Posted : 01/06/2012 12:41 pm
Glue, always.
Posted : 01/06/2012 12:42 pm
Glue, always.
Why?
Posted : 01/06/2012 12:43 pm
Last place I worked at swore by tape.
Thie means they probably both work OK, tho tape is meant to be a lot less messy.
Posted : 01/06/2012 12:55 pm
there's already glue on the rim and the tyre. Do I need to go through the 2 coats and letting it dry in between routine?
Posted : 01/06/2012 1:04 pm
 LS
Glue, always.
^ This
Tape seems a good idea if you've not done it before but glue is quicker, easier, and less grief in the long run. Glue also gives a much better bond, hence why we use it for CX when there's less pressure pushing the tub onto the rim.
Posted : 01/06/2012 1:09 pm
can you use that conti glue on carbon rims? It says alloy on Wiggle
Take your time with glue and you don't get gunked up.
Of course this only applies to any tub other than Continentals, which I refuse to use any more because they are so f#<kn b'stard tight to fit.
Yes, but how many times do i need to go over the rim and tyre if they're already coated?
Posted : 01/06/2012 1:31 pm
 LS
Ideally you'd use the same glue again but if you don't know what was on before, probably one coat on each should be fine.
If it was e.g. Conti before and you were using Conti again then for road use I'd just put one coat on the rim and remount.
Make sure both surfaces are dust/grease free first by going over with a bit of rag and some acetone.
Posted : 01/06/2012 1:40 pm
no idea what glue was on before as it was on when I got them last week.
THink I'll talk to the guy at my LBS when I take the wheel in to get the spoke replaced
Posted : 01/06/2012 1:41 pm
 LS
If it's a clear glue then it's probably Conti or Vittoria. I've mixed those two before without any hassle. If it's a darker colour it might be one of the older kinds of glue which have been banned and they don't really work when mixed with the modern ones.
Posted : 01/06/2012 1:49 pm
Back when I used tubs a lot I used tape and never had the bond fail. Much easier, quicker and less messy
Posted : 01/06/2012 2:07 pm
Glue on wheels I;ve just bought is yellow-ish. New or old?
Posted : 01/06/2012 2:12 pm
 LS
Probably new, the old ones only appear now on older wheels or from people (I know a couple 😀 ) who have a load of Dunlop or Clement glue in the garage from years ago and are gradually using it up.
Posted : 01/06/2012 2:17 pm
Glue for me. I used the Conti stuff on carbon rims no bother.
Posted : 01/06/2012 2:43 pm
Raced on tubs for years and years with tape, still do, never had a failure.(Having now said that,I will die doing the crit this Tuesday night ive entered)
Posted : 01/06/2012 3:16 pm
