Tubless ready cyclo...
[Closed] Tubless ready cyclocross tyres - recommendations ?
[#8281333]
Morning all
Anyone have any recommendations for a tubeless-ready cyclocross tyre, 700c, say 35mm width ?
Thanks in advance
Posted : 11/01/2017 3:10 am
To suit what conditions? WTB Cross Boss 35 is a big 35. Not a mud plugger though, more of a trail tyre.
Posted : 11/01/2017 6:23 am
Just something general really, probably see more use on the road but some tame off-road too. Not planning on doing anything too mucky.
Posted : 11/01/2017 7:05 am
I've put spesh trigger pro 38c 2bliss on mine
Not much in the way of knobbly bits so good on tarmac / gravel and they're OK around 35 psi. Not gone much lower (tbf I'm running them higher now it's mostly Road duties) but reports have em burping around 25psi
Edit. They come up about 34mm and are quite stiff due to casings
Posted : 11/01/2017 7:08 am
I am quite pleased with my Hutchinson Toros 32mm and more of a winter tyre, they also do the 'black mamba' in 34mm with fewer knobles as a more summery option.
Posted : 11/01/2017 8:41 am
I have a pair of Hutchinson piranha in 34mm I thing at home.
Brand new and unused if they are of any use?
Tubeless ready
Posted : 11/01/2017 8:43 am
Sounds like you needs some file treads? Will go for the default recommendation of what I have despite no experience of other tyres: bonty cx0.
Fast on road, gravel, dry surfaces, fine when a bit damp too.
Posted : 11/01/2017 8:53 am
Big fan of g-ones unless mud is involved.
Posted : 11/01/2017 9:51 am
Ritchey WCS Shield Cross - pretty fast, 35mm, tubeless ready. Had the non-tubeless variant set up as tubeless, worked pretty good.
Posted : 11/01/2017 10:09 am
I have a cross boss because I couldn't get a nano to fit on the rear.
Only ridden it once, but seems ok on general trail conditions.
Posted : 11/01/2017 10:32 am
Cross Boss is good. Tubeless is very easy on my UST rims but may struggle on Stan's.
Decent all round tyre but if you have a heavy road bias something with a file tread or more consistent centre line might be best. Lots of options around now though.
Clement X'plor now come in tubeless varieties.
Posted : 11/01/2017 11:05 am
For all round crossing clement pd or mxp are awesome.
for gravel/road: some file tread like the speedcross tyre.
Posted : 11/01/2017 11:32 am
Leigh
Tubeless ready
Have PM'd you - cheers
Posted : 12/01/2017 12:55 am
+1
Posted : 12/01/2017 2:04 am
