Tubeless: what am I...
[Closed] Tubeless: what am I doing wrong?
[#4889796]
Hello All,
I bought some Joes No Flats and fitted it to my front wheel with Nobby Nic EVOs with no problems. I then turn to the back wheel about a week later. Followed the same process and wheel goes up okay. However, there seems to be a number of leaks from the side wall where sealant comes out but they do not seem to be sealing properly. Hence the tyre is soft after a number of hours.
Do I need new/different sealant, a new tyre or an inner tube!
Cheers as always
Dogsby
Posted : 20/02/2013 7:00 pm
Happens with non tubeless tyres I find. You need to ride them a bit to keep the sealant swirling round and seal all the holes. If there´s plenty of sealant in there then I´d go for a local ride with a good pump 🙂
Posted : 20/02/2013 7:06 pm
Sit the wheels horizontal on a bucket for half hour, repeat other side. The holes should have sealed
Posted : 20/02/2013 7:12 pm
Yeah, pump it up and go for a ride seems to be the best way (and leave it on it's side overnight afterwards).
Posted : 20/02/2013 7:15 pm
+1 on top of the bucket and flip over after 5-10 mins.
Posted : 20/02/2013 7:18 pm
Steve, Mark,
Cheers for that idea and I am now giving it a go. It is actually on the kitchen table on a bowl as Mrs D is away, otherwise it would be in a bucket in the garage!
I will let you know how it goes....
Dogsby
Posted : 20/02/2013 7:25 pm
You are not using a UST tyre or a UST rim.
Posted : 20/02/2013 7:42 pm
I don't think you are actually doing anything wrong; non-TLR, non-UST Schwalbe tyres tend to have thin, porous sidewalls.
Posted : 20/02/2013 8:09 pm
Did my rear wheel last friday.
Nobby Nic Evo, non ust on stans crest with yellow tape and sealant. Took a few attempts at getting the bead the pop. Finally managed it, was leaking so did the jiggle and rotate. Thought it was leaking a touch so laid on the side in a bucket as recommended. Did approx 30 mins each side. Has held most of the pressure so far. Loads better than the Rocket Ron I tried. Was as soft as a soft thing after a couple of days.
 JoeG
POIDH! 😀
Posted : 20/02/2013 9:18 pm
When I set my wheels up tubeless I ran the bath and rotated them till I could see where the leaks were then gave them a good shake with that area at the bottom. Seemed to work well and they have stayed up since I was lucky as Mrs Orange was working that day so I got away with it.
Posted : 20/02/2013 9:31 pm
The tyre is holding up well this morning. Thanks for all of the advice.
Dgsby
Posted : 21/02/2013 7:51 am
Right, still suffering from a slowly deflating tyre. I have now put it is a sink and it appears to be leaking from the base of the valve where it goes into the rim. Whilst under water I can see sealant slowly leaking out into the water but no air. I suspect there is a fault in the rim strip so might be sending it back to CRC. Any thoughts?
Dogsby a
Posted : 24/02/2013 1:30 pm
One of mine did that and I found loosening the valve rather than tightening it helped the seal. Just about finger tight and a bit of wiggling then left wheel with valve at bottom for a while. Been fine now for 2 years.
Posted : 24/02/2013 1:43 pm
You could try cutting a small circle of old tube and stick it over the valve hole. Then shove the valve through that.
Posted : 24/02/2013 1:52 pm
If you've got sealant in there I'd try holding the wheel out in front of you, with the valve furthest from you (if that's where it's losing air from) and adopt a 'panning for gold' motion, to slop some sealant around the base of the valve on the inside.
Schwalbe tyres always leak a little IME, but the snakeskin sidewall variety are much better,(and feel better on the trail too, at lower pressures). HTH
Posted : 24/02/2013 1:53 pm
If air gets past the rim strip / tape it tends to get into the hollow section of the rim & comes out through the valve stem. I tend to use several layers of electricians PVC tape wound tightly onto a clean rim to seal it. I have tried to use yellow tape but it was too wide for my rim & did not seem very flexible. I also use some mastic on the inside of the valve stem as it goes through the tape for surity.
I've just put a new set of Racing Ralphs on a new set of Crests which were incredibly tight - wrecking a set of tyre levers. After using up 4 Co2 cartridges with soapy water I had to resort to my compressor to get them to 'snap' into place.
Posted : 24/02/2013 1:55 pm
