Tubeless valve leak...
[Closed] Tubeless valve leaks .......
[#6793288]
when I unscrew the inner to pump it up
seems to seal when I screw it up again but may have a slow leak and I don't really trust it
can you replace the valve cores only?
thanks
Posted : 19/01/2015 10:53 pm
Best check the rubber hasn't split where the valve enters / exits the rim. Had a similar slow leak and realised there was a slight split that began to leak when tightening down the screw on nut.
Posted : 19/01/2015 11:05 pm
Presta valves have a little leak I find when you unscrew them, but all sealed after screwed back up.
If it's a removable core valve, make sure the core is firmly screwed in place unless you want to remove the core. Has flat sides you can do it up with a mini spanner.
Then, use plenty of sealant generally and it will all seal up.
Posted : 20/01/2015 1:00 am
