Tubeless tyre defla...
[Closed] Tubeless tyre deflation
[#2061254]
WTF is going on? New(ish) 819 & an old but good Mud-X, lots of stans fluid and the tyre is sitting happily on the rim - looks fine all the way around both sides. No fluid coming out of anywhere but the bugger is going down in a couple of hours?
Thoughts?
Was kinda getting to like this tubeless malarky now I have a compressor, but rapidly going off it.
Posted : 06/10/2010 12:57 pm
you checked for leaks with water/soap/. valve leaking? rims?
Posted : 06/10/2010 12:58 pm
hmm use a low tech solution like that, pah not likely, is there no specialist tool that costs the earth I could buy instead?
<runs off to fill a bowl of water>
... I just expect the stans fluid to come out of the same hole the air is...
Posted : 06/10/2010 1:04 pm
Biggest source of leaks I had when getting tubeless sorted was air leaking out between the valve seat and the rim, then leaking past the valve & out of the spoke holes too.
Tightening the valve nut sorted it.
I found the best place to check for leaks was the bath. Makes it very easy - just the wheel/tyre though, you don't need to also get in!
Posted : 06/10/2010 1:40 pm
The Mud X is only 'tubeless ready' as opposed to UST so can sometimes take a while to get sorted. The bath test is probably your best bet unless you have a mahoosive bowl/bucket.
Posted : 06/10/2010 2:09 pm
Kitchen sink just about did the job, g/f's WFH so couldn't risk the bath.. well all the air pissing out the sidewall, even though there still a load of stan's fuild inside.
Any thoughts? Do I try leaving it on it's side (pumped up or not?)
I wanted to ride with this bloody thing tonight! Guess not.
Posted : 06/10/2010 2:20 pm
whack it up to 40 psi and ride (take a pump just in case) it will sort itself out, as the rotation of the wheels and the compression of the tyre swirls the sealant all around.
Posted : 06/10/2010 2:21 pm
hold the wheel 'flat' and just rock it gently back/forward and side to side - you need to get a good coating of sealant all over the sidewalls.
Posted : 06/10/2010 2:23 pm
Do what wwaswas said first, then do what I said.
Posted : 06/10/2010 2:24 pm
yeah, your tyres are pourous. they'll seal soon enough once you start riding!
Posted : 06/10/2010 2:27 pm
Fit a tube! KISS
*runs away giggling*
Look at the video here:
http://www.cyclistno1.co.uk/features/maintenance/stans-no-tubes-guide.htm
Posted : 06/10/2010 2:41 pm
Just ride them. Simples
Posted : 06/10/2010 3:11 pm
Just a quick thank you, leaving them on there side has fixed my issue, I'd had them stood on a wheel building stand and was spinning them regularly to swish the latex about, obviously not enough in this case.
There even still up this morning.
Posted : 07/10/2010 2:14 pm
wwaswas - Member
Agree with this, can take a while to get sidewalls sealed properly.
Posted : 07/10/2010 2:17 pm
When putting them on the side use a bucket to place them on so theym nicely horizontal.
Posted : 07/10/2010 2:37 pm
