Tubeless tape advic...
[Closed] Tubeless tape advice
[#9684387]
I have "Tube less ready" rims. Rodi black Jack 40's
What's the ideal rim tape size, I'm assuming 40 is too wide, as the bead takes up the edges so I need roughly 30mm?
Posted : 23/11/2017 10:03 pm
Should only need to cover the spoke holes, so doesn’t need to be that wide
Posted : 23/11/2017 10:10 pm
Stans max is 27mm so go for that then?
Posted : 23/11/2017 10:17 pm
I go with internal width + 5mm.
Personally think its best to go up the sides to prevent movement when seating/ removing tyres.
Posted : 23/11/2017 10:19 pm
cant go wrong with WTB yellow tape - available in loads to widths
http://www.chainreactioncycles.com/wtb-tcs-tubeless-rim-tape-11m-roll/rp-prod66624
Posted : 23/11/2017 10:20 pm
[quote=jimmyoto ]I go with internal width + 5mm.
That.
For instance, my 45mm (internal) WTBs use 50mm tape. This is what WTB recommend for their rims.
Posted : 23/11/2017 10:21 pm
DT do 42 mm tape designed especially for 40 mm internals.
Posted : 23/11/2017 10:31 pm
Thanks, I have a CRC voucher, so I guess wtb 45mm is the way to go? I take it the tape isn't thick enough to cause bead seating issues on a tubeless ready rim? As the rim edges do appear quite shallow
Posted : 23/11/2017 10:57 pm
Some of the width of the tape is also taken up by following the contour of the well of the rim.
Posted : 23/11/2017 11:10 pm
This ^^
Posted : 23/11/2017 11:17 pm
One issue with tape is that when you are levering tight tyres on, the tyre can dislodge the tape as it falls in to the well. This might be more likely if you go for narrower tape on a wide rim.
I find cutting down wide Gorilla Tape isn't too much of a faff and means I can get exactly the width I want.
Posted : 24/11/2017 9:40 am
Surely you want the tape to cover the raised ledge that the bead sits on to provide a better seal. Otherwise you would have high pressure air trying to get under the edge of the tape, not to mention sealant trying to get at the glue on the tape.
Posted : 24/11/2017 12:39 pm
Wtb 45 mm tape ordered, I actually emailed the manufacturers and to my complete surprise got a reply the next morning advising this was correct. The reply was from their export manager, so hats off to [url= http://www.blackjack.pt ]www.blackjack.pt[/url] customer service there 🙂
Posted : 25/11/2017 9:51 am
