Tubeless setup leak...
[Closed] Tubeless setup leaking from valve
[#7510828]
Any ideas/suggestions on how to prevent this? The valve is on pretty tight, and the valve itself isn't damaged. Current thinking is sacrifice a tube and go slightly ghetto...
Posted : 11/12/2015 4:48 pm
 Yak
Probably the tape is damaged / lifted somewhere and the air/fluid has migrated round to the valve hole. Remove the tyre and re-tape.
Posted : 11/12/2015 4:51 pm
It's often a bad cut of the rim tape. Stans recommend using a small round file to get ride of any overlap that might prevent the valve seat from, err, seating properly.
Also - if there is a leak anywhere else round the rim it can often manifest itself as a leak from the valve hole.
I assume you've put lots of fluid in and done the Stans jiggle?
Posted : 11/12/2015 4:52 pm
Had a leak from the valve in a crest a few weeks ago. After much head scratching and eventualy removing the rim tape i discovered the cause of the leak and the creaking back end. Rim was cracked through the tyre well.
Posted : 11/12/2015 5:14 pm
yup retape or keep trying to get the jizz round the valve so it seals better.
Posted : 11/12/2015 5:50 pm
yiu can use the rubber O rings that works, simple to
Posted : 11/12/2015 6:25 pm
Or Copydex / wood glue?
Posted : 11/12/2015 9:56 pm
PVA works for me - used it on a problematic Arch rim conversion a few weeks ago - it's still up, nice and firm.
(ooh err)
Posted : 12/12/2015 12:17 am
I had problems with Stan's Crest rims leaking from the valve,tried a new valve still had the problem.A couple of weeks ago I ended up taking the tyre off replacing the rim tape but it still leaked,as a last resort I put extra sealant in the tyres & both tyres have stayed inflated
Posted : 12/12/2015 12:41 am
