Tubeless rim tape w...
[Closed] Tubeless rim tape width query ?
[#10107474]
for Hope Tech XC rim - so 19.5m internal.  I have 25mm Tesa tape already - will it fit or should I buy the 19mm stuff ?
Posted : 23/07/2018 3:20 pm
I would say stick a bit on and see. You usually want the tape to go up the sides a bit and if the rim bed is concave too that adds on another bit.  Normally I would say about 23mm for a 19mm rim so you may find 25mm is fine. Others may say differently
Posted : 23/07/2018 3:25 pm
I go with the external width of the rim. As above, once you pull the tape down into the bed it ends up being the right width.
Posted : 23/07/2018 3:27 pm
cheers for that, the Hope rim has an external width of 24mm, so will try the 25
wheels have landed 🙂
Also bought some Stans 21mm tape, so will have a try with both the 21 Stans and the 25 Tesa tapes and see how they fit...
Posted : 02/08/2018 1:11 pm
I've got 25mm tape in my WTB 19mm rims. Just get it in nice and tight and press it down with an innertube.
Posted : 02/08/2018 1:34 pm
