Tubeless rim strips
[Closed] Tubeless rim strips
[#2820169]
Are the rim strips e.g. stans actually necessary for converting a standard rim to run tubeless?
Posted : 05/06/2011 4:06 pm
You can make your own from bmx inner tubes.
Posted : 05/06/2011 4:27 pm
It would seem cheaper, but surely there must be more to them than that for £16
Posted : 05/06/2011 6:16 pm
No, I just use a loop of gaffa ape with a couple of inches either side of the valve hole overlap and go over with electrical tape. It's worked countless times for me.
Posted : 05/06/2011 6:19 pm
The "Ghetto" approach is the most cost effective IMO; Gaffa tape and BMX inner tubes have worked a treat for me up to now.
I presume anyone buying a pair of Stans strips has "MUG" tattooed across their Forehead.
Posted : 05/06/2011 6:23 pm
It's always worked for me, I use the super-lightweight Maxxis ones for my 'best' wheels!
If the tyre is a bit loose, I put a layer of double-sided foam tape under the rimstrip.
Posted : 05/06/2011 10:38 pm
