Tubeless repair kit...
[Closed] Tubeless repair kits.
[#12120573]
Which one?
https://www.chainreactioncycles.com/mobile/lifeline-tubeless-repair-kit/rp-prod177626
This any good?
Posted : 21/11/2021 12:48 am
Yep- it's not as convenient or as quick as most of the new types like dynaplug etc but then it's very cheap. I was pretty impressed with how big a hole it can seal.
Posted : 21/11/2021 12:57 am
Ok cheers, the price difference to others made me wonder if that kit was ok.
Posted : 21/11/2021 10:04 am
Can get spare worms from flea bay (and elsewhere)
Search on
Tubeless puncture 1.5mm
(Or 3.5mm or 6mm), I find it best to have the range of sizes
Posted : 21/11/2021 10:14 am
 aide
I have that very kit, not used it in anger but I did drill quite a few holes in an old tyre to practise on and it done the job
Posted : 21/11/2021 10:49 am
Are the anchovies different (to just anchovies) in these kits with added rubber glue etc?
Or are these kits just anchovies+ ?
(I have one, and I still don't know if I can just use the anchovies out and about!).
Posted : 21/11/2021 11:08 am
The main benefit I’ve found of using the glue is that it eases the insertion of larger anchovies.   All have lasted the remaining life of the tyre for me regardless of whether I used the glue
Posted : 21/11/2021 11:33 am
granny_ring
TBH I suspect it's the same worms etc as in the Weldtite kit, just in a different box. Seems to perform just the same anyway.
The fancier methods are almost entirely about convenience and speed, and compactness- my Dynaplug's tiny in comparison so I can carry it easily in a tiny pack or even a pocket if I wanted.
Speed and convenience can be a bigger deal than it sounds, since flats always happen at a bad time. Also I had a puncture a while back, heard it start to go, jumped off, stuck my finger on it, one-handed the dynaplug out of my bag and stuck it through before the tyre was even flat. I was riding again in just a minute or two. Up til then I thought the speed thing was mostly for racers but that made me think again. Mind you I might never get such a perfect run again, it was like an F1 pit stop.
Posted : 21/11/2021 5:56 pm
I've used my Lifeline kit once and it worked perfectly.
Posted : 21/11/2021 9:02 pm
@ Northwind 😂
Bit annoying that I didn't order the other day when I ordered some inner tubes..... Controversial... 😂
Posted : 21/11/2021 10:39 pm
Thats a decent kit. Theres nothing to stop you pre-loading the barbed prong and putting a short cut section of garden hose over it to achieve a 'quick fire' plug dispenser for your pocket/bag.
Next level up is this:
Tyre repair
Posted : 21/11/2021 11:26 pm
Cheers will look at that slug plug too 👍
Posted : 23/11/2021 12:45 am
