Tubeless Rear Press...
[Closed] Tubeless Rear Pressure
[#5180060]
what do you run yours at? im thinking of running my rubber queen 2.2ust back on the back of the bike again, i took it off initially for 'summer' but with it being wet im getting no traction out of the xking on the rear....
so to combat the slow draggy feel of my rubber queen 2.2 ust on the back, im thinking of running it with a higher pressure instead of the usual say 25-28psi
if i increase it/top it up regularly to about 34 psi will it roll that more efficiently on road sections? or will it make bum all difference to rolling resistance?
Posted : 22/05/2013 2:32 pm
I run 28psi in the rear on my FS & HT, both the same tyre (2.1" Ground Control) set up tubeless, could probably get away with less in the rear on the FS, but hey to.
Posted : 22/05/2013 2:39 pm
Usually run my rear 30-35 anyhow but then I'm 90kg. I tried it at 45psi the other day (for an event with a lot of road in it) and it was much harsher on the chattery off-road stuff where the suspension wasn't kicking in, I'd only say it was worth that compromise if you're doing a majority of your riding on the road, otherwise run it at off-road friendly pressures and put up with the on-road performance.
Posted : 22/05/2013 2:40 pm
 Yak
2.2 x-king or race king at 19psi
I wouldn't bother upping it for road sections. I doubt it will make much difference. I had mine down to 12psi by mistake recently and whilst drifty on the descents, I doubt it slowed me much on the climbs.
Posted : 22/05/2013 2:41 pm
Stans recommends weight in pounds divided by 7 then plus and minus 1 or 2 for front/rear to get values in psi.
Works for me!
Posted : 22/05/2013 2:43 pm
32psi (92kg)
Usually run 30R/28F for dry conditions. Rode last night having not checked the pressures for a couple of weeks and checked them when I got home and found 21psi in the rear. Was great over the rooty, rocky stuff that last nights ride spat at us but dragged like a dead sheep on the road linky sections. (2.2 nevegal 29er)
 Yak
As Ianfitz/ Stans said, but I go -1 for the rear and - 5 for the front
Posted : 22/05/2013 2:46 pm
 D0NK
25.8psi ha ha
great traction no doubt and about right for front, but I'd trash many, many rear tyres.
Posted : 22/05/2013 2:48 pm
mine often do go down slowly, then you suddenly realise a month or so on it feels a bit squishy by hand and low and behold its down to 19psi
so ill just try and keep it topped up to 32 psi'ish and see how that rolls!
to be fair when i was running the RQ out back i reckon it could well have been low 20's for most the time i found it draggy
Posted : 22/05/2013 3:21 pm
Doesn't it depend how heavy you are? I tend to be around 30, and just guess on the trail if it's super sloppy.
Posted : 22/05/2013 3:23 pm
Approx 28psi. 95kg.
Posted : 22/05/2013 3:24 pm
well im only 11.5 stone ish kitted up, so not mr.blobby, i can get away with them really low under 20's when ive come to top them up/forgot and never had an issue
just dont like the drag on the road, and conti dont do a black chili ust x king so i may just bung the rq bc on the back and use a little more pressure
Posted : 22/05/2013 3:27 pm
Yes, I use the "weight in stones X 2" and add two for the rear tyre and subtract about two for the front. So for me, 24R and 20F. Seems about right.
Posted : 22/05/2013 4:05 pm
High Rollers LUST at 25 PSI front and rear.
Posted : 22/05/2013 9:55 pm
