Tubeless issue.
[Closed] Tubeless issue.
[#8033252]
I have a stans ztr crest wheel that is all set up for tubeless with a nobby nic tubeless ready tyre on it. Had it up to 35psi but over the course of the last 7 days it seems to have lost a lot of air from just being stood in the garage. I cant see any evidence of sealant coming from anywhere so where is the likely slow leak coming from? Any pointers as i am a noob with tubeless wheels.
Posted : 03/09/2016 3:03 pm
Some folk are so tubeless-ist that they'll creep into your house in the middle of the night and let your tyres down. Does happen.
Posted : 03/09/2016 3:07 pm
Did you set it up? Is it a new tyre with sealant added and swished around?
If so most likely the valve.
As a side note 35psi is high, second best thing about tubeless is being able to run low pressures , but of course its personal pref.
Posted : 03/09/2016 3:08 pm
Sounds like thats pretty high pressure for tubeless. Air will just leak slowly through the rubber anyway, I tend to add a bit more sealant when the tyres start to lose air significantly over a week or so.
Posted : 03/09/2016 3:09 pm
Maybe from round the valve? Try pumping them up a bit and see if you can see any bubbles. Have you ridden them yet? Sealant might just need a bit more of a slosh around
Posted : 03/09/2016 3:10 pm
TBH going down over a week isn't really a bother- ideally you want them totally airtight but as long as they keep proper pressure for a full ride, that's all you really need. Often they seal up better after a couple of rides, as the sealant gets into all the niches and it beds more perfectly on the rim
Posted : 03/09/2016 3:22 pm
NW is sort of correct however if they are leaking it suggests that the sealant has not worked so I would not be that confident they will resist a puncture. Not sure though as none of mine leak - though some did intially when set up and I found riding was the best fix.
Posted : 03/09/2016 3:30 pm
Try and waggle the valve about and see if it leaks where it goes into the rim, if it does it might just need tightening up a bit. I had this last week.
Posted : 03/09/2016 3:56 pm
The valve is in good nick with a new core in it and its on very tight. I thoroughly checked it for leaks but cant see any. . The tyre is nearly new and has plenty of stans in it. I havent ridden on it yet but i did do lots of shaking/bouncing of the tyre to circulate the sealant and i left it on its sides as well as per advice. Its also done a fair bit of spinning in the frame but will definately give it a ride when the monsoon here stops.
The tyre is only at 35psi from the initial set up and hasnt been ridden on. I normally run it at just below 30psi, any lower and it feels too draggy over the grassy moorland and heather i ride on.
Edit: thanks everyone for the responses,much appreciated.
Posted : 03/09/2016 4:22 pm
It'll seal much better after you've ridden it. Going down like that over a week when newly set up is very normal.
Posted : 03/09/2016 4:25 pm
This. Every tyre I've ever set up tubeless leaked air for a while. Ride it and it should be sorted.
Posted : 03/09/2016 4:44 pm
Mine were going down over night until I did a good ride, even then they lost a little air over a few days. Couple of riders later and they are much better. I always check the pressures if I haven't ridden for a week or so though......
Posted : 03/09/2016 7:06 pm
30psi lol Try 20 front 25 psi rear bit more depending on weight
I leave mine at 40 psi overnight to make sure their well fitted then let them down. Just done a week of MTB not a single issue and same pressure on Maxxis HR and Ardent rear
Posted : 03/09/2016 8:00 pm
You could try laying on its side for a few hours. Get a bucket and balance it on top so that it is flat and level, leave it for a while or over night and then flip it over and repeat. It let's the sealant sort out any minor leaks in the side wall. I had NN issues a couple of years ago and this sorted it.
Dogsby
Posted : 04/09/2016 8:12 am
It needs riding.. Go take your bike to the woods
Posted : 04/09/2016 8:25 am
Thread ressurection time. I took your advice and went for a ride and all was good so left the bike in the garage for a few days to see if it slowly went down. Went to check it this morning and the tyre is flat as a pancake and has partially come off the rim. Its a fairly new tubeless ready nobby nic with no evidence of a leak/hole anywhere,also new valve.
I might try my purg which is on the front just to check its not a wheel issue,other than that do you think it might be new tyre time.
Posted : 10/09/2016 9:13 am
 br
IME tubelessing used tyres is usually a PITA, as they've usually already got holes in.
Posted : 10/09/2016 9:16 am
Is it possible to set the tyre up and then dunk it in water to try and find any possible escape routes or is it likely to be too slow.
Posted : 10/09/2016 9:46 am
I'd give it another go. I've had new tubeless installations go completely flat after seeming to be OK. Just pump the tyre up, do the multi directional shake, have a ride etc again and see what happens, there's a good chance it'll seal up.
Posted : 10/09/2016 11:04 am
Tyre keeps blowing off the rim now using floor pump. I think the bead might be broken as it looks kinked at the point where it comes off the rim, is that possible?
Posted : 10/09/2016 2:08 pm
