Tubeless Anchovies ...
[Closed] Tubeless Anchovies puncture fix thingys
[#8292667]
So had my first tubeless puncture that did not seal yesterday.
4mm cut across the top of the tread on my Schwalbe S Ones. Lots of Stans sprayed under the mudguard but to big for it to seal.
Had invested in the Genuine Innovations tubeless seal kit last year and chucked it in the commuter rucksack.
So on a coldish wet dark night it was going to be a good test of the practicalities of real world use.
Dug out the little fork tool thing and pulled an anchovie from the kit. This was a small challenge but managed to get it free. It then took a couple of minutes to thread it into the tool. I dare say with practice you would get faster (might be an idea to pre thread one and keep it in a wee bag to save time).
Jabbed the tool into the hole (takes a bit of pressure to get it in) gave it a quick twist and pulled. It came our easily leaving the anchovie in place. Pumped the tyre back up to 80 psi with no leaking. Puncture fixed without even having to take the wheel off!
Two days of riding on it now and no loss of pressure.
Overall pretty impressed, will be interesting to see if it holds up longer term but definitely takes the hassle out of fixing a puncture. Worth the £5 and couple of grams of weight.
Posted : 17/01/2017 10:35 pm
My question is how do you get the anchovies off the plastic backing?
The ones in my kit seem to be completely stuck fast...
Posted : 17/01/2017 10:36 pm
It was a bit of a challenge but it does come off with some brute strength and ignorance.
Posted : 17/01/2017 10:39 pm
If you lost alot of stans worth topping it up
Posted : 17/01/2017 10:43 pm
with the weldite kit, I had to open the gap on the pronged tool up to get a anchovy through it.
but yeah, they're great. even used two in a massive hole before.
Posted : 17/01/2017 10:58 pm
Best part of a year for the ones currently hangin out of my back tyre. Don't seem them causing a problem before the tyre dies
Posted : 17/01/2017 11:04 pm
Top up of Stan's on the to do list for tomorrow.
Posted : 18/01/2017 12:10 am
if you can find them, these are great: http://www.tredz.co.uk/.Sahmurai-Sword-Tubeless-Tyre-Plugs_85836.htm
you could of bodge your own.
I have fitted them to my tubeless bike in France and means Ive got something to help out me or a friend if we cut a tyre in the Alps. This especially as I tend to ride with minimum kit.
Posted : 18/01/2017 12:18 am
I've used, I think, the same ones as jam bo and also had to widen the little fork tool. it came with a little tube of lube stuff which I managed to get all over my hands. Turns out the lube helps bond the rubber strip. I ended up with melted / dissolved rubber all over my fingers.
Worked a treat though.
Posted : 18/01/2017 9:25 pm
It's not lube, it's vulcanising solution 🙂
Posted : 18/01/2017 9:36 pm
And I guess that would be why I had sticky rubbery stuff everywhere!
PMSL.
Posted : 18/01/2017 10:22 pm
Posted : 18/01/2017 10:55 pm
Weldtite actually do TWO tubeless kits.
One is intended as an external repair kit, with said anchovies, whilst the other has a strip of rubber to cut from and a tube of rubber cement and internal patches.
Posted : 19/01/2017 12:15 am
Stoner - Member
I got a set of these for Christmas but was a bit disappointed as they are too tight a fit in my bars. I reviewed them [url= https://orena45blog.wordpress.com/2017/01/08/review-sahmurai-s-w-o-r-d-tubeless-puncture-repair-kit/ ]on my blog recently[/url].
Posted : 19/01/2017 1:58 pm
