Thinking of going tubeless using the Stans No tubes kit...
I heard that in theory this works with normal tyres... is this really the case, or will I get better results using UST tyres, or any other kind for that matter.
If it make any difference I am running panracer fire XC at the moment, but also have some mountain kings that I could use instead.
You can seal ANY tyre , some take a bit of time and patience . Mountain kings will seal up first go , ive had no experience with panracers.
[i]Mountain kings will seal up first go [/i]
Maybe they will, maybe they won't...That's the beauty of rim strips, really, it's a whole new world of arsing about when you should be riding. You can do everything according to the instructions and the f%^&er might not want to inflate.
Decide which is the least embuggerance in your life, the occasional puncture, or faffing about with bits of rubber and latex.
Take the whole wheel to the service station after you have put your stans fluid in it , take the valve core out , stick the garage's air on it and you WILL inflate and pop the bead in on any tyre in 2 seconds flat .
