Tubeless
[Closed] Tubeless
[#7282903]
Is there an idiot's guide anywhere to the current state of tubeless technology - tyres, rims, pumps, pressures, sealants, etc?
Posted : 22/08/2015 4:12 pm
I recently went tubeless, couldn't find such a guide... Just do lots of googling. Find out if your rims are tubeless ready and go from there
Posted : 22/08/2015 4:17 pm
 core
Google your specific combination, something usually comes up.
I read a few, turns out my rims aren't ideal, had a bash anyway, worked.
De-burred spoke holes, 2 layers of 1" gorilla tape, tubeless valve, 2 scoops of stans (29er), Aldi track pump, went up first time, did the shakey, spinny thing, lost a few psi first night, added more air, went for a ride, no burps (was mostly fire road bashing), fine ever since.
Sun Ringle Inferno 25 with non tubeless Conti X King.
Posted : 22/08/2015 4:22 pm
Just do it ghetto style, with a tube two sizes down.
It pretty much seals from the off, regardless of rim or tyre.
Did my FS with Gorilla tape & valves etc, but it was a lot of faffing about. Ended up taking it into the lab at work, where even that was a struggle to get it inflated from an industrial airline.
(Folding 3C Minions on Mavic something's).
Did the 27.5+ wheel for my other bike a couple of weeks ago & went back to ghetto. Straight up with an old track pump, no faffing. For the few grams weight saving, I'll just use a split tube from now on. That was a WTB Trailblaster, on a cheapo Alex rim).
Fluid wise, I used Stans.
Posted : 22/08/2015 4:32 pm
I found lots of people saying Infernos wouldn't work as well but mine went up fine too
Posted : 22/08/2015 5:55 pm
Another "bmx tube" ghetto user here.
I Just put it over normal rim tape, added sealant, soapy beads & a blast of co2. Did use tubeless ready tyre but otherwise a doddle.
Posted : 22/08/2015 6:27 pm
I used stans strips. Could have done it ghetto but got the strips cheap at LBS
Posted : 22/08/2015 6:33 pm
Same rims as me.
I've just given mine to my flatmate who works in a lbs to tubeless up. Hopefully he doesn't have any problems with them, was planning on riding later today 😀
Posted : 22/08/2015 7:15 pm
And fwiw, they went very easily apparently, fair enough they had a compressor, but no issues. Gorilla Tape instead of Stans, proper set of tubeless valves and no problem.
Posted : 22/08/2015 8:39 pm
Hmm, done some googling and, lacking a compressor, it all sounds a bit of a ball-ache. I'm getting thorn punctures where I'm riding at the moment; probably just go with some sealant filled tubes for now and do tubeless properly next time I get new wheels. Thanks anyway.
Posted : 23/08/2015 8:14 am
Seriously, it's about the best 30 mins you can spend on your bike.
Once done your thorn worries are over. 🙂
Now, go buy a track pump, a pair of 20" tubes & some Stans fluid...
Posted : 23/08/2015 8:24 am
 core
Honestly, have a go, if you do it ghetto, especially with gorilla tape which is dirt cheap, it doesn't cost bugger all, and is pretty simple, I've always got them inflated with a track pump, on gorilla tape & stans rim strips.
Thorn punctures is the main reason I use them, you'll be amazed how many thorns that you never knew about are in your tyre when you take it off the rim in the future.
Posted : 23/08/2015 8:29 am
 Muke
Ghetto tube setup like they said ^^^
Not really, depends how bothered you are about punctures
OK, vid looks straightforward enough, might try that next time I put a new tyre on. Trouble is, I'm old enough to remember this...
Posted : 23/08/2015 10:03 am
