truvative stylo cra...
[Closed] truvative stylo cranks - removal advice please
[#2991983]
whats the procedure for getting them off and will i need any special tools
Posted : 28/07/2011 8:58 pm
8mm allen key turn anticlockwise on non drive side and it'll come off. Reverse to refit. The 16mm fitting is only used when they are first put on. They need quite a bit of tightening when you put them back and check for play after your first ride. I had to re tighten after a couple of rides.
Posted : 28/07/2011 9:21 pm
Do they need a lot of force used on the allen key as I've had a go at getting them off tonight and just using hand force aint shiffting them, should I use a hammer?
Posted : 23/08/2011 8:40 pm
stylo 8mm is 48-54Nm so it's gonna be tight 🙂
I normally use an 8mm 3/4" bit on a ratchet or long torque wrench
to get mine on and off.....
I wouldn't use a hammer - find something to use as a lever.
Posted : 23/08/2011 8:46 pm
Yes they do take a bit of undoing and doing back up again.
Posted : 23/08/2011 8:54 pm
thanks folks I shall give it a bit more whelly err...leverage tommorow 😉
Posted : 23/08/2011 8:58 pm
