Just received one of these, it looks ideal for grease-guarding, but I'd need to get the alloy spacing-collars off the axle to take the bearing seals off.
I've not used isis before, I take there is a shoulder on the axle against which the bearings sit...do the cranks push against the spacers?
Posted : 17/02/2011 10:40 am
*bump*
Posted : 17/02/2011 7:31 pm
Hey AL
I'm sure you should be able to remove the alloy spacer, they are quite tight though.
What exactly are you trying to do?
Posted : 17/02/2011 7:52 pm
