Truvativ X0/X9 Doub...
[Closed] Truvativ X0/X9 Double Chainsets????
[#1830805]
Anybody know how much and when they are due to the UK?
XTR is due October time but £349.99!!
Posted : 25/07/2010 9:05 pm
Both due 28th August,
X.9: £260
X.0: £387 without BB (oddly exactly the same as XX, so expect imminent price rises!)
Even XX is heavier than XTR, if that's a factor, however IMO the SRAM ratios are better, having the narrow range of XTR seems to rather defeat the purpose of the object!
Posted : 25/07/2010 9:53 pm
Thanks for the info.
XX was out of price range and so is the XO now!!
This double chain ring set-up is tricky.
XTR with a change of change rings seems the likely option at the moment. But limited, with buying the needed size rings.
Posted : 25/07/2010 10:12 pm
TA Chinook come in every size you could want, and can be fitted to any chainset you like. I used to run 28/40 on M970 cranks, was a good combo, if you're going 10 speed with an 11-36 cassette I'd go wider on the rings, I'm currently running the 28/42 and it's spot on.
Posted : 25/07/2010 10:16 pm
Will look at the TA rings
Posted : 25/07/2010 10:17 pm
Do you need a different set of chain ring bolts or a spacers due to the missing material thickness of the other chain ring?
Posted : 26/07/2010 12:49 pm
