Just got a cheapish Truvativ Carbon Noir chainset of a buddy..
After around 45-60 mile later the arm(LH) on the spline has movement when holding both by my hands.
Cant see the slines worn(steel) so has to be Alloy arm yeah ?
Anyone else come across this thing ?
THX Jv..
A common problem, if in the past it wasn't fitted correctly, tightened enough the crank arm would wear and never be right again.
Can maybe pick up another crank arm from a decent sized bike shop that has some old/used/spares 'out back'
what was your buddy's reason for selling it?
Hed jst forked out £350 for a XTR one...
Nevermind eh !
Been looking & found someone who deos LH arm For £98 ?
But my RH sides well scuffed up LOL...
I've got a spare noir 175 lh crank you can have for £50 if you want it.
I had this happen on a truvativ crank on my fixie to the point where it was coming loose every ride and had clearly damaged the taper on the crank.
I managed to fix it by cleaning all the mating surfaces (eg splines on crank and axle, bolt threads and internal threads on the axle and using a good threadlock plus doing it up b@stard tight. Never came loose again.
