TRS E*Thirteen Cran...
[Closed] TRS E*Thirteen Cranks - how do you remove them?!
[#7368215]
Tried following the installation instructions in reverse - removed the retaining bolt with a 8mm wrench, but twisting the APS (?) collar doesnt pop the non drive crank arm off. What am I doing wrong?
Seems over engineered, not to mention the need for a £15 specific tool to change the rings....
Posted : 04/10/2015 9:30 am
[url= http://service.bythehive.com/Guide/How+to+install+TRS+and+LG1+series+cranks+using+APS/7 ]Install video[/url]... if you've removed the bolt holding the non-drive side cranks on, just give the arm a tap with a #1 screw driver (hammer/mallet) to release it.. the abs is purely to take up the slack, it won't 'release' the arm, assuming I've understood your issue.
Posted : 04/10/2015 10:05 am
Thanks Zippy, that's the issue - I got the impression that the ABS was some sort of extractor, as well as taking up slack. Out with the hammer then!
Posted : 04/10/2015 10:14 am
The cranks should have come with a tool you thread into the crank bolt to pop the arm off the splines
Posted : 04/10/2015 10:28 am
As Catfish says they should have come with a specific tool for that purpose. It looks likes a replacement crank bolt but is shaped to loosen the arm from the interface.
Posted : 04/10/2015 10:45 am
catfishsalesco - Member
No idea what tool you guys are talking about, my set didn't need anying special & if you watch the install video, you'll see it's 'basically' like a HT 2 axle fitment wise
Posted : 04/10/2015 12:18 pm
This - http://buy.bythehive.com/TRS-race-crank-arm-fixing-bolt-and-removal-tool
Looks like the crank bolt that attaches the non drive said, but is described as also being the "removal tool" - confused.
has the bolt come out of the non-crankside arm? It's been a while since I used the crankset, but IIRC, it might have pulled the crankarm off as you undid the last bit.. hang on I'll go look at my set in the garage.. BUT I definitely have no special tool and have fitted/removed it a number of times.
Posted : 04/10/2015 12:23 pm
Checked everything with my bike, no removal tood. The installation instructions dont mention one in the E13 video.
Posted : 04/10/2015 12:59 pm
Pulled my old set out of storage, ok the non-drive side arm bolt is integrated into the arm, you need to unwind that & the arm should come off (or maybe need a tap with a mallet, I wasn't advocating more than that)... My set are from 2013, but I wouldn't have thought they'd have redesigned it that much
Posted : 05/10/2015 8:20 am
They have been redesigned, saw a set like yours in my LBS last week. Waiting on the tool from e13, but worried I stripped the thread trying to do the job with an ISIS tool. Angle grinder anyone?!
Posted : 13/10/2015 8:15 pm
