Tricross steel disc
[Closed] Tricross steel disc
[#4352294]
Seeing as Specialized dont seem to be importing the Tricross triple steel disc;
http://m.specialized.com/us/en/bikes/multi-use/tricross/tricrosselitesteeldisctriple
Does anyone else make a steel do it all disc eqipped all rounder triple?
Must be triple as i have some pretty steep hills to climb that I can only do on a triple in the granny ring at the moment which rules out the Genesis CDF/Croix and I dont want to buy one and have to change to a triple straight away.
Posted : 11/09/2012 8:59 pm
if a bike comes with a triple sti (some do IIRC) swapping to triple would be easy/not too exp.
Posted : 11/09/2012 9:01 pm
Whats the rear cassette on atm . Surely a compact double and an mtb cassette would see you right ?
34:32 lowest gear ?
Posted : 11/09/2012 9:02 pm
2013 tiagra rear mech has been tweaked to run a 32 or 34 low gear
Posted : 11/09/2012 9:08 pm
 Bazz
Build your own? Kaffenback f+f and Tiagra groupo will set you back around £500, so depending on your budget you could even get your lbs to do the spannering if your not confident.
Posted : 11/09/2012 9:17 pm
