tricross - SS to ge...
[Closed] tricross - SS to geared conversion?
[#226605]
is this possible? are the dropouts replaceable or would i have to use a hub gear?
ta
Posted : 19/01/2009 11:55 am
dmr do this;
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=11037 ]dmr gear hanger thingy[/url]
Posted : 19/01/2009 11:59 am
hmmm
interesting thanks
Posted : 19/01/2009 12:02 pm
 JoB
your biggest issue is going to be that the rear-end is 120mm spaced so there's no chance of getting derailleur gears in there, i haven't bothered to see if you can get a 120mm spaced hub gear because i suspect it wouldn't be worth all the hassle
Posted : 19/01/2009 12:03 pm
ah, i thought that might be an issue
shame as there are quite a few about and i fancy a SS winter bike/geared tourer
Posted : 19/01/2009 12:06 pm
What about an Alfine hub gear, would that go on a 120 spacing. Did I see a pompino with that done on the On-One site?
Placed an order for a tricross on Friday so hopefully will have it tomorrow. I might even look into making it fixed.
Posted : 19/01/2009 12:41 pm
doesn't really offer enough choice for touring, the gears are too widely spaced
it'd have to be a rohloff and they are a little too pricey!
Posted : 19/01/2009 12:52 pm
Its SA or nowt for the spacings. I have looked.
Posted : 19/01/2009 2:35 pm
Pompino comes in 135 and 120 flavours. The Alfine is 135. Like mattsccm says you're limited to 120 size hubs. I think there might be SRAM 3speeds that fit as well SA
Posted : 21/01/2009 11:16 am
