Trek sizing 2014 v ...
[Closed] Trek sizing 2014 v 2015???
[#6741349]
Anyone know anything about trek sizing changes from 2014 bikes to 2015?
I'm looking at a superfly HT. The 2014 bike is available in a 9.7 but an 18.5in frame. The website states that it's suitable for a 66-70inch height. Spot on if true as I'm 68in. However, the 2015 HT superfly says that the 17.5in frame is suitable for heights of 66-70in (!). I'm totally confused as to what size bike I should be looking at.
Posted : 01/01/2015 6:13 pm
Forget the number on the frame. Find an actual geometry chart and work from there.
Posted : 01/01/2015 6:15 pm
They have not changed there sizing.My 54cm ones/17.5" are the same as they have been for years.
Posted : 01/01/2015 6:52 pm
Superfly geometry changed from 2014. Before that they offered 17.5 and 19in. From 2014 it's 17.5, 18.5 and 19.5.
I'm either a 17.5 or an 18.5. 5'7.5 with a 32" inside leg. Arm span is exactly the same as my height. Problem is further compounded by trek's geometry chart which says that a 18.5 actually has a 17.5in frame size. I've no idea if this also applies to 2014 bikes.
There are a limited number of 2014 9.7s available with £400 off. But only in size 18.5.....hence my dilemma. What I actually want is the 9.8 X1 however it's £800 more (£2400 v £1600). Dilemmas, dilemmas...!
Posted : 01/01/2015 7:01 pm
 br
A riding pal just bought a new 2015 Trek, it's a size up from his 2014 Trek - he remarked that he's glad he went to sit on it, rather than just order the same size.
Posted : 01/01/2015 8:51 pm
B r - thanks for that. That explains everything. So if I'm reading this correctly, he had to buy one size smaller for the 2015 bike compared to the 2014?
Now I just need to decide what one I actually want. Hopefully get a sit on a 18.5 2014 tomorrow.
Posted : 01/01/2015 8:55 pm
Trek sizing has not changed between 2014 & 2015 . At 5ft 8 you will almost certainly need a 17.5 frame .
Posted : 01/01/2015 9:03 pm
At 5' 7" my 2014 18.5" suits me perfectly. 18.5" was introduced in 2014 and is the same as the old 19"
Posted : 01/01/2015 9:37 pm
Ignore the size on the bike, look at geometry and TT length. It's far more relevant.
Posted : 01/01/2015 11:36 pm
So what geometry and top tube length would you suggest ?
Posted : 02/01/2015 1:13 am
My superfly 8 is 17.5" 2014 and I am over 5"8 18.5" would be to big for me.My 17.5" is the top number on the frame sticker not bottom one.
Posted : 02/01/2015 9:15 pm
