Trying to find a replacement bearing for my 2018 fuel with knock block. The upper bearing is a bit worse for wear but struggling to find a replacement.
I know it’s 1-1/8” bearing but the trek breakdown says it’s knock block specific.
Anyone know the exact spec and where I could get one from sooner rather than later. Thank you.
Found the complete kit on blazing bikes but just need the top bearing!
Posted : 11/04/2020 9:23 pm
Should be a 30.15x41x6.5mm 36/45*
FSA stamped MR122, TH-873E
MH-P03k aftermarket code
Posted : 11/04/2020 9:31 pm
Thank you. Find these on eBay so hopefully be ok!
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F143380970891
Actually thanks to your info also found
Posted : 11/04/2020 9:35 pm
