Trek Ex8 replacemen...
[Closed] Trek Ex8 replacement bushings/bearings
[#2395336]
Hi,
Can anyone please tell me where to get replacement bushings and bearings for my Trek Ex8. I think it is either 2006 or 2007 but not totally sure.
I need the bushings for the rear most pivot and also the bearings for the four points on the swing arm.
Any help appreciated, thanks
Dave
Posted : 23/01/2011 6:50 pm
Any Trek dealer should be able to source a set for you, you'll need the frame number(usually on the bar-coded sticker under the down tube)for them to order the correct ones.Can order them for you if you haven't got a local dealer, feel free to call us at Sunset on 02920371321, won't be in 'til late tomorrow, but others should sort you out.
Posted : 23/01/2011 7:33 pm
Thanks mate, will try LBS Blazing Saddles.
Posted : 23/01/2011 8:01 pm
