Does the "control freak" plastic thingy come out of the downtube so I can get a new zip tie around the internal cables? I had to replace a cable so the zip tie obviously had to be removed.
It does on my slash, just a tiny hex bolt. That said, it's only a finger size hole, so not sure how you would get a cable tie in,
Yep. As above.
The lower covers just drop out when you snip the cable ties... getting the new cable tie to go around all the cables/hoses in the frame however is a complete arse (from my attempts!).
Yes.
Use a spoke to fish it back out again to make you life easy.
Also worth folding the end of the ziptie to help as well.
Cheers. Nothing dropped off when I cut the existing zip tie. Might just need some waggling then I guess.
