Trek Crossrip heads...
[Closed] Trek Crossrip headset help required.
[#9940403]
OK, picked up a Crossrip LTD frameset (2016) a day or two ago.  The upper part of the headset is missing (upper bearing still present, though) and I was wondering if anyone knows the correct headset for it.
The Trek website is rather vague on the model but it appears to be a pressfit/semi integrated one.  (sealed/cartridge bearings)  I can take measurements but Cane Creek's headset finder seems to suggest that it is an IS41 headset.
I'd probably try to cannibalize another similar headset for the upper part, (compression ring, seals, etc) first, as the upper and lower bearings are nice and smooth but will order a new one if this is not possible...
Any advice would be most appreciated...
Posted : 13/04/2018 10:47 am
Contact your local Trek dealer?
Posted : 13/04/2018 10:56 am
 Bez
The original part on a 2016 Crossrip is a VP A61ACK, and I've also fitted an FSA Orbit IS-2 CC. If you google those you should find the spec.
Posted : 17/04/2018 10:05 am
