Travel change on Pi...
[Closed] Travel change on Pikes?
[#7060370]
Hello all. I'm thinking about taking the plunge on some 2015 Pike 160mm Dual Position. The worry I have is that 160mm might be a bit much so would it be possible to reduce the travel easily and cheaply in the future if required?
Posted : 12/05/2015 10:38 am
I've got the 150mm dual positions. The forks are pretty stiff so I don't notice any downside of the travel and I doubt an extra 10mm will make much difference so you'll be fine i'm sure. I'm not convinced by the dual position thouhgh. I chose DP for the same reason you are considering them, but actually find I never use the functionality. The front end of the bike can get a bit light and vauge on very steep climbs, but i've just got used to that so don't bother with dropping the travel. If I were doing it again i'd just get the Solo's.
Posted : 12/05/2015 10:47 am
Thanks for the reply and interesting to hear you don't really bother with the travel adjust.
What I really need to know though, forgetting the travel adjust bit is can the main position (160mm) be changed by removing/adding spacers like my Fox can or would it be a pain? E.g go from 160mm with 130mm travel adj to 140mm with 110mm travel adj?
Posted : 12/05/2015 10:56 am
I've got the 160 dpa pikes as well, I'm sure you can't add spacers to adjust travel.
I leave mine at 130 most of the time and only switch to 160 on the rougher/faster/steeper stuff.
Posted : 12/05/2015 11:21 am
Cheers . 😀
Posted : 12/05/2015 11:22 am
You can change the travel on Pikes by changing the air shaft, lots of options available as 1 shaft does diff travel on 26/27.5/29 forks.
I've just bought a 150 shaft to change my 160 DP Pikes. They are like hens teeth in UK, but readily available in Germany;
http://www.gabelprofi.de/Nach-Hersteller/RockShox/Air-Shaft-PIKE-Dual-Position-Air-160mm-travel-26-150mm-travel-27-5-can-be-used-to-change-travel-to-160mm-on-26-150mm-on-27-5-A1.html
Lots of info here; http://forums.mtbr.com/santa-cruz/reducing-pike-150-140-160-150-tech-thread-889096.html
Posted : 12/05/2015 12:15 pm
