Anybody got a list needed for the mighty maestro linkages and main bearings etc??? A friend is in great need and I need to fit them for him asap - apparently! Ta.
They're written on the seals on all of them, so if you've got time to take a bolt out of each pivot on one side, just read them & go to your lbs (local bearing supplier)
Was hoping to cut out the reading if the numbers and go directly to LBearingS. Haven't got his bike over yet 😉
rr - thanks but I think I will avoid purchasing from the man who thinks the bearings not rotating easily makes for good rear linkage action 😉
you could email him for bearing codes?
Think I will read the codes of the bearings first - cant bear communications with him.
Thanks for the suggestions.
BETD do a kit for £40 if that's any help...
