Having trouble with my settings on the Trance with Fox Talas RLC forks.
On the rear shock Fox RP2 - how many clicks of rebound are people using?
Also With the talas fork, - how many clicks of rebound? How much low speed compression damping?
on my 09 talas i use, rebound 3-4 clicks from full on, lsc 3-4 clicks from off, rebound may seem a bit slow but once im moving it feels smoother than running it faster and it dosnt feel like its packing down
lsc depends how fast your going and how much sag you run if they are set up xc firm or plush, the more sag you run the more lsc you need, slow and steady you dont need any imo but once the speed picks up i find 3-4 clicks keeps it more stable and less divey any more and it gets harsh, unless your riding 4x then you wind it full on for max berm pumpage
hmmm - any more answers?
I have 09 talas - usually 2 click from off here but if doing tech slow bolder sections then prob 5 clicks from off to stop jerking forward d.t. over compression and me over the bars otherwise 🙂
3 on the front, 4 on the back.
so you change your rebound during the ride?
Sometimes if its a long ride with a big variety of terrain I do 🙂
jam bo - TTP as usual?
bump
