Trailer vs Panniers...
[Closed] Trailer vs Panniers for a road-based cycle tour
You haven't seen my skinny legs druidh 🙂
Posted : 12/11/2010 11:38 am
but I've got huge feet infront on the trailer bag
Posted : 12/11/2010 11:40 am
I look like spike milligan drew me
I'm inclined to agree with skidartist on this one.
Anyway, what about the price and usefulness of each option? If you intend to do a fair bit or touring investing in racks and pannier might be worth it. Most folk might need to get stronger wheels for the extra weight of those panniers at least, especially if you have a more modern road bike with lightweight wheels. This could get expensive. Then there's the faff of fitting panniers to get heel clearance and bolting the racks in the right place. Touring bikes are longer in the chainstay for better stability and heel clearance.
However a trailer, while a decent cost on it's own, might be much cheaper. Your bike won't need stronger wheels as the trailer wheels take a lot or all of the weight. This means you can use a normal road bike ( as one of the posted pictures show). It's a more simple set up. You don't have to pack as carefully as the bag is bigger (less carefully doesn't necessarily mean more weight) and you don't have to spread the load evenly. You can also bolt the trailer to other bikes you have, and getting a single wheel one like a Bob means you could off road touring as well.
So even if the bikes do handle the same, the trailer may be a cheaper, simpler and more versatile option. Obviously depends on your circumstances but itd be my first option to try.
Don't forget a bar bag though. Best thing in the world for touring!!
Posted : 12/11/2010 11:44 am
Some useful thoughts on decoupling a load here:
[url= http://www.carryfreedom.com/downloads/Trailer%20Science.pdf ]Trailer Science[/url]
I own a Carry Freedom City trailer. I use it for heavy loads like shopping and in my experience it's easier to handle than a similar load in panniers.
Now, when touring you shouldn't really have such a heavy load! Light is good. I have used dry bags on bars / top-of-rack and a frame-fit bag when touring and found that a great solution. I found it a very aerodynamic and light way to carry gear on a bike.
Hope that helps!
Posted : 12/11/2010 11:50 am
 kcr
Another practical advantage of panniers for me is that I can easily have all my kit to hand inside the tent (one man Terra Nova - rear panniers and one front inside the fly space and one front with valuables inside the inner). I think that would be difficult with one big trailer bag. Separate panniers also make it easier to strip the bike down if you want to carry it into the woods to find a quiet wild camping spot.
I've never used a trailer, but I have always assumed that the handling must be a bit more stately - surely you can't flick the bike in and out of corners so smartly when you are pulling all that extra wheelbase behind you?
I did think one trailer solution I saw an American couple using was quite smart. They were touring with folders, and the hard shell flight cases for the bikes converted into wee trailers that they towed behind the bikes.
Posted : 12/11/2010 11:51 am
IME panniers especially front ones do add significantly to the wind resistance. Even just rear ones does. However I don't know how thios would compare to a trailer.
As for cost - I don't know there is a huge amount in it if you get quality racks and panniers The setup on the tandem was a couple of hundred pounds - tubus racks front and rear and carradry bags front and rear.
However I am convinced there is no extra effort involved in balancing the mass once above walking pace. Our set up (tandem) touring is well over 200kg all up weight.
Posted : 12/11/2010 11:52 am
The ideal with a trailer is you shouldn't need to change anything about you're bike, lower gearing is nice, but thats about it. You don't need to have a dedicated touring frame, or stronger wheels.
A trailer pack isn't more cash than a pair of panniers, a trailer is more than a rack, but its cheaper than buying an extra bike. It was mentioned above that you could save the money for a trailer and buy a lighter tent, but a hundred and odd quid is only going to shave grams off a tent. If you're already invested in panniers - you've got a bike with braze ons, low bb, strong wheels, racks and panniers and you're accustomed to riding it then is a bit of a step to switch to a trailer as you make all that other stuff redundant. But from scratch a trailer is the cheaper way to go.
Bar bags give me the boak, if you've got panniers on you might as well use one too, but on their own - no chance. But theres a tiny wee pack that topeak make that sits behind the stem and means you're camera is always to hand, they're ace.
Posted : 12/11/2010 11:53 am
I recently bought my wife a Topeak bar bag, under £30 and it looks quite small. However its just the right size for keys wallet phone etc, well padded and converts to a good bum bag thing when you take it off. Also the bracket for it has a removable mount to put computer or lights on so it gives you back the bar space the bag mount uses. Really excellent - more and more impressed with the Topeak one.
Mind you it doesn't have a map case like mine does which is invaluable. Not having to stop to figure out directions is fantastic.
Posted : 12/11/2010 12:07 pm
That trailer science link was great almost totaly data free
I'm sure trailers are fun but I'm really not buying the balance effort thing at all.
It is fun reading made up physics though 😉
The only bit that sounded true was the the thing that Skidartist said about stop start utility biking. If I was riding around town with a big load getting on and off then I think a trailer would save time and effort as you do have to hold the bike up as you get on. But my touring experience has been that you don't do that very often.
There might also be a load where the benefits of a trailer kick in and it may be around 36Kg. The only time I ever felt I was fighting the bike was riding into Auckland from the airport. I had say 16kg of touring gear in panniers and about 20kg of climbing gear in an 80 litre rucsac strapped onto the rack. That was hard work and balance felt odd. But you'd need to be carrying a months food to reach that kind of load
Posted : 12/11/2010 12:15 pm
it's an attractive idea that aerodynamics suffer with panniers but I doubt any of us can really state that authoritatively, or that it's significant. There are too many other factors.
Posted : 12/11/2010 12:16 pm
 kcr
Anyone remember the front panniers from the early 80s with the curved leading edge profile that actually claimed to improve aerodyamics...!
Posted : 12/11/2010 12:21 pm
Trailer Science
That wouldn't be at all biased would it?
Complete junk science too - they mention that it costs more energy to lean a bike with panniers on, but then go on to suggest that you lean your bike all the time because of "every time they turn their pedals they and their bike wiggles, slightly to the left then slightly to the right. That’s a slight wiggle every turn of the pedals, 60 times a minute, 3600 times and hour." I don't suppose they'd stopped to consider that you might just put the same amount of energy into this wiggling but wiggle the bike a bit less. Also "as cyclists turn corners, again the bike will lean left or right" - which uses how much energy (I suspect they don't understand how a bike balances either)?
It is good that link - full of assertions with no explanation.
However if the panniers moving side to side wastes energy ( and i believe it will) this is only at very low speeds - at higher speeds gyroscope precession and self castoring hold it vertical
The same movement however would yaw the trailer (move side to side this wasting the same energy)
My[i] [b]guess[/b] [/i]would be that on the flat a trailer is marginally more efficient mainly from aerodynamics but once you do a lot of stop and start or hills the panniers would be as there is less total weight to be lifted or accelerated.
Very marginal tho.
Posted : 12/11/2010 12:22 pm
cynic-al - Member
True but I do have anecdotal evidence - a wide set of front panniers ( big rears as well)on the tandem our top speed down glencoe was 35 mph. On similar roads without panniers we reach 45+easily mph.
Lots of factors for sure but certainly the frontal area was greater and it appeared to me that the aero drag built more quickly that without the panniers
Posted : 12/11/2010 12:25 pm
I'd say the same as TJ regarding the panniers aero drag - have no hard data, but I've ridden the same bike on the flat with and without and there's certainly a slight speed decrease with.
Not that I'm convinced there's actually less drag with a trailer because it's sitting in your draft - so are my panniers.
Posted : 12/11/2010 12:28 pm
interesting TJ but that is a huge difference in speeds to be accounted for by the panniers. Doesn't wind resistance increase exponentially with speed?
Posted : 12/11/2010 12:34 pm
Some friends of mine are much slower downhill on their tandem when they are towing a trailer. I can actually freewheel beside them. I don't think panniers would be any worse.
I've never used a trailer, but I do like the idea on being able to ride a road bike and just unhitch the trailer for day if I want a nice light bike for a circular ride.
Posted : 12/11/2010 1:25 pm
al - wind resistance does increase exponentially with speed. Thats why you reach a terminal velocity. with the panniers the terminal velocity was a lot lower.
Anecdote tho - and it was a big wide pannier setup
Posted : 12/11/2010 1:37 pm
'I'm totally aware of how bikes are balanced when you ride them, but its naive to imagine they are balanced without any input from the rider, I'm not saying its enormous, but when the load is heavy its enough for there to be a benefit detaching that load from the bike.'
vs
'But a bike (loaded or not) will quite happily balance all on its own when going at speed. How much effort do you really think it takes?'
it takes a lot less energy than pedalling, but since we constantly steer / lean a bike to keep it upright and that takes input, it does use energy - concentration as well as a small amount of muscle power.
bikes are balanced at all speeds not by centrifugal force, but by the rider steering into the sideways fall, thus keeping the c of g hovering around the centreline / balance point between the wheels at all times. how our c of g is balanced and how it interacts with teh steering geometry and moves around this centre line is what determines bike handling.
centrifugal force adds stability but is not what keeps the bike upright in the first place. if it did, you could 'ghost' a bike down a long straight hill for miles. in reality it veers to one side and falls. at low speeds this shuffling of your c of g over the centre line, back and forth, requires steering input. so when touring, more energy is expended by steering / balancing a bike with heavy panniers on than when towing a trailer. your steering input has to move bags on teh fork as well as teh frame in most cases. since touring involves (ime) a lot of time going slowly uphill and steering input per mile is greatest when climbing, there's a sound reason to say that less energy is used in controlling a bike (not just pedalling it) when the painners are lighter, or better still, the load is supported independantly on a trailer.
a similar example - i've found more stable road bieks to also be better over long distances, not because less twitchy steering means i move less ansd save energy that makes the difference, but because i need less concentration when tired to keep it on line. it's subtle but it's noticable that i feel better on the more stable bike teh more tired and slower-reacting i get.
Posted : 12/11/2010 1:45 pm
James - yuo forget gyroscopic precession and castoring - those are two effects that hold the bike upright.
Posted : 12/11/2010 1:48 pm
yes TJ...but a 30% increase in speed means an even greater reduction in wind resistance - panniers alone could not account for that and so something else must have been at play.
Posted : 12/11/2010 1:58 pm
Al - think about he nature of it. Yes other factore could be in play but 30% increase in frontal area? Two big fat panniers on a wide mounting at the front of the bike?
It may not be the only answer but on that tour I really felt the two big wide front panniers increased wind resistance significantly.
Only anecdote tho
Posted : 12/11/2010 2:01 pm
TJ, castor helps you steer by adding stability at speed, gyroscopic affect also adds stability but the principle of your c of g moving around the centreline is what actually keeps you balanced over the 2 wheel's axles. castor and gyro are only a part of it by aiding stability as speed increases. think of how you balance when ttrackstanding )
a bike can be steered without any castor at all, and super-light wheels that have little gyroscopic effect against a 100kg rider, because of the principle above. it wouldn't handle well, but you could ride it )
Posted : 12/11/2010 2:02 pm
you're right on the wind resistance thing TJ, it makes a huge difference. cervelo focus on drag more than weight as once you're over around 12-15mph the ratio of weight of a rider vs bike is less significant compared to the frontal area of rider vs bike.
Posted : 12/11/2010 2:04 pm
James - gyroscopic precession is a self stereing mechanism as is castor.
At high speed they provide the stability
think about rolling a wheel down a hill - no bike. At high speed it goes straight - its only as it slows that it falls over - oir think about the gyroscope balancing.
Posted : 12/11/2010 2:05 pm
you're right, they add stability. but the wheel will tilt and fall at any speed, it cannot carry on indefinately.
this is a real QI question for cyclists, you may be suprised by how many designers and even non-cycling physics types say castor and gyro or one of the two, but those two only aid balance at speed. 'steering into a fall' is what makes it possible to ride a bike at very slow speeds or trackstand to stay upright. and we all do it all the time without thinking about it - it's the 'eureka moment' when you learn to ride a bike - how much steering corrects the fall and how much is too much.
another example, think of how a slack angled dh bike can be carved from one extreme lean to another more easily than a road bike. the castor and gyro effect aid stability, the castor (long trail) is really just adding to the ability to swing your c of g from side to side with control, ie to pull it back from a fall / extreme lean angle without crashing.
ps edit to say that wheel example, it only goes straight if you set it off straight..
Posted : 12/11/2010 2:12 pm
also, think about how you initiate a turn. you steer momentarily against the direction you want to go to initiate a lean/fall to the side you want to turn to. you then steer in that direction of the turn to balance your c of g on the centre line of the wheels for that given radius of turn (or close of the centreline, as centrifugal force balanced against your weight will also come into this, but then it's getting more complex to discuss and i'm not into the maths there!)
heavier wheels and longer trail / castor effect make it a bit harder to steer / be bounced off-line / initiate a turn due to the stabilising effect you point out, and therefore they feel more stable. it's because they both work against you steering into the fall initilly, but alone are not enough to stop you steering - or to keep the mass of ther rider upright above the axles. that would require some weird gravity )
Posted : 12/11/2010 2:19 pm
apologies for the hijack there OP )
frame bags are a good compromise - it's what i'd use next time alongside a rack-pack and a small rucksack for light bulky items though the rucksack did limit my speed to about 50mph in the Alps last time i did a light-road tour there. caught the wind quite noticably, maybe 5mph slower than the same road w/o a bag?
side-winds may be an issue with a frame bag but that may be a blessing on some days..
Posted : 12/11/2010 2:27 pm
TJ its not just about frontal area.
and as its exponential (square IIRC) its not 30% but more like 70%.
Al- have a think aboiut it. You have got your exponential s muddled
Wind reistance is proportianal to frontal area. Its exponential to speed.
So at a steady speed double the frontal area double the #wind resistance. As speed increases wind resistance increases exponentially.
so 30% more frontal area = 30% more drag.
As I said tho it will be multifatorial but it felt to me like that set up of very fat wide front panniers increased wind resistance singnificantly
James - have a read up on gyroscopic precession. Its really weif#rd but it does hold the bike in a straight line - as I say think about rolling a wheel down a hill. its gyroscopic precession that holds it straight and upright.
Cornereing ( at speed) You want to turn right. You steer left. Gyroscopic precession topples the bike to the right and moving the contact patch to the left topples the bike to the right - this initiates the turn. as the bike leans gyroscpic precession returns the bars to the midline. Cornering force is not generated by steering angle - it is generated by camber thrust from the wheels. You remain in a steady state of cornering with the bars in the midline unltil you initiate a corrective steering movement.
However wobbling is different. Riding along in a straight line and start to topple to the right - gyroscopic precession turns the bars to teh right which then steers the bike to teh right bringing the contacvt patch back under the cog. self correcting.
Posted : 12/11/2010 2:48 pm
Frames bags, better load distribution and less wind drag than paniers.
Posted : 12/11/2010 3:05 pm
TJ, you seem to be assuming that gyroscopic precession / effect is more influential than your own steering input or placement of your c of g in relation to the axles, but it isn't. the gyro effect of a 1500g wheelset rotating at whatever rpm it does at 10-40mph is a small force compared to the pull of gravity on you. i can hold a spinning wheel at the axle and move it about at arm's length, but i'll bet i can't move you about at arm's length. also, your wheel example, it will fall pretty quickly. gravity will take care of that and it's tilting around its base, not pivoting at the axle. it doesn't pull itself upright as it rolls faster, which would be in support of the gyro argument if it happened. (edited, not 100% on this bit tbh - but it will fall based on its c of g and base stability right?)
I understand the basics of gyro precession - don't ask me about the maths or physics in detail ) but i know what you mean. we've all played with a spinning wheel and many of us of a certain age or older had gyroscopes as toys when we were young, but it's not true that the gyro influence of the wheel is what makes a bike 'work'. it helps at high speed, that's all.
"Cornereing ( at speed) You want to turn right. You steer left. Gyroscopic precession topples the bike to the right "
in fact, you steer left, your centre of gravity moving onto the right side of the line between the tyre contact patches makes you fall toward the left, not the precession. you then steer into this fall and carve a line to the right. precession will influence and aid this by being a force to react against that will help to lean the bike but it's not the significant force at work here. it's proportionally greater as speed increases, it does aid stability and yes, in turn steering, but it's not why a bike is steer-able in the first place. for precession to aid stability or steering we have to get up to a speed where the gyro effect is significant, and that involves steering using your centre of gravity. precession can't be a factor on a slower, technical trail either as the speeds are lower, more variable and the wheel is moving around too much to build any satbility. here it's 99% c of g steering.
bikes are brilliant really, always falling to some extent but always upright while the rider has influence and control over their c of g.
if gyro precession was the main reason a bike worked, i'd be spending less time looking at bike fit, rider positioning and front end trail etc, and more time working on wheel size and weight (que a pro-29er argument, or a 'so that's why your bikes suck' comment from someone!)
Posted : 12/11/2010 3:22 pm
James of corse both factors are at work but You underestimate the effect of gyroscopic precession at speed. it is what keeps you upright
How would a wheel roll down a hill without toppling without this effect
Posted : 12/11/2010 3:26 pm
Factor this!
Posted : 12/11/2010 3:33 pm
Oops double post
Posted : 12/11/2010 3:34 pm
Certainly looks more aero without front panniers.
Posted : 12/11/2010 3:36 pm
Aero drag? What drag?
Posted : 12/11/2010 3:38 pm
in those pics above, it's steering not gyro effect that keep them upright ) TJ and I could've saved a lot of typing with one of those images )
TJ, camber thrust and gyro precession are both things that would need far better mathematic ability than i have to understand what level of influence they have on riding a bike, what i'm getting at is that it's steering and the rider and bike's weight / position of their weight that has by far the greatest influence at most riding speeds and hence why i feel that panniers (esp on the front) mean you need a bit more effort to control the bike.
the wheel will roll upright for a while, gyroscopic effect will mean it will stay upright far longer than if it was static, but its c of g is central and it will fall before it hits a speed where it can stay upright. but in theory, could it stay upright at a crazy-high impossible speed if the road and wheel were 'perfect'? ie when the gyro forces massively outbalance the wheel's weight? wouldn't it need some kind of counter-weights hanging down each side from the axle for the precession to act against?
Posted : 12/11/2010 3:54 pm
it also depends on what bike you are planning to ride,
on a tourer or audax or mtb, you should have plenty of heel clearance, but on a more racy bike you may not, in which case a trailer may be better.
if you are taking a fair load, you may also need to think about uprating the brakes, 50mph onto a roundabout with the brakes full on aint fun, trust me!
above all, the object is to have fun, so enjoy!.
Posted : 12/11/2010 4:52 pm
But what about fruitcake? In a crash fruitcake would be much better protected on a trailer than in a pannier. If you kept your pump on the trailer its far less likely to get caught in your sock and your fruitcake wouldn't get damaged on one side.
Posted : 12/11/2010 5:40 pm
We're complete noobs at tandeming, yet we managed to balance this just fine, even at silly low speeds, and a few 'sports beverages' inside the captain ... :
Posted : 12/11/2010 5:56 pm
A shorter pump, thats the answer.
Pumps shortened while U wait
Does your lovely daughter like Tizer? Eh?
Wouldn't mind buying her a bottle of Tizer.... if it's available in this area, that is.
Posted : 12/11/2010 6:15 pm
TJ you are wrong. typed out an explanation but lost it.
one of us is a maths graduate remember 😉
Posted : 12/11/2010 6:38 pm
Page 2 / 4
