Trail building - Cl...
[Closed] Trail building - Clearing out thorny bushes
[#9431965]
I'm hoping to build a few small trails in a local wood if the landowner is happy.
The ground is covered in thorny bushes, only 1-2ft deep but it is fairly thick in places.
What's the best way to clear a singletrack through this with no powertools?
Posted : 12/07/2017 11:21 am
Can you get/buy/borrow petrol tools? Petrol brush cutters or strimmers are good. Failing that try a sythe! If possible while using it try to dress like the grim reaper to scare local folk..
Posted : 12/07/2017 11:25 am
It's a horrible job, use fire as chopping at them is a last resort, you'll need something really sharp with a long handle.
Posted : 12/07/2017 11:30 am
Get into the base and take them at ground level with a saw. Everything else is not an efficient use of time.
Posted : 12/07/2017 11:31 am
All my tools are electric although I may be able to borrow a petrol brush cutter.
I'll be doing this on evenings so noise may be a bit of an issue though.
Would you normally put some weedkiller down once it's cleared to kill the roots?
Posted : 12/07/2017 11:43 am
Failing that try a sythe! If possible while using it try to dress like [s]the grim reaper[/s] Ross Poldark to scare local folk..
Posted : 12/07/2017 11:44 am
I helped with ground clearance at the new pump track in Edinburgh. Best results were long handle snips to get in at the base and then whack with a sturdy rake
Posted : 12/07/2017 11:58 am
Fire is quieter than petrol tools.
Posted : 12/07/2017 12:04 pm
Machete on a stick!
Posted : 12/07/2017 12:53 pm
If you can't use power tools then a bush hook (2nd from left) is pretty good, follow that up with a rake or use a hoe to clear the ground.
Posted : 12/07/2017 1:01 pm
Or a billhook?
Posted : 12/07/2017 1:02 pm
Thanks, the bush hook looks perfect! Will get one ordered.
Posted : 14/07/2017 1:48 pm
Don't go lobbing "weedkiller" about in a woodland. Not unless you know what you're doing. Or fire either.
Posted : 14/07/2017 5:31 pm
As my learned colleague above commented.
I'd suggest a saw like the one in soma's pic. For a beginner, using edge tools at ground level will soon stop them working.
(edit) Or loppers if the stems are too thin and bendy for a saw.
Posted : 14/07/2017 5:54 pm
Brash hook/slasher.
The local Gurkhas cleared the bramble from the forest school are quite effectively with just some branches. Got the bramble to catch and then just kept wrapping it round and round the stick
Posted : 14/07/2017 6:06 pm
Fiskars XA3, XA23 if you want the longer handle.
My fave trail tool.
Posted : 14/07/2017 6:30 pm
Scythes are for grass, and a lot harder to use than they look. A slasher if you've got room to swing it, a billhook if you haven't is what you need.
Though what you really need is a petrol or rechargeable electric brushcutter 😉
Posted : 14/07/2017 7:27 pm
Salt...
Posted : 14/07/2017 8:01 pm
I'd be taking a long handled lopper as said ^ up there
Posted : 14/07/2017 8:32 pm
