Is there any carrier that doesn't use the main towball and still allows a caravan to be towed ?
Asking for a friend. I think the bike will be squashed between car and caravan.
Yes. Speak to Pendle.
[url= http://www.pendle-bike.co.uk/shopping/higher-wheel-support.php ]Pendle Wheel support rack for towing[/url]
Maxxraxx...I have a four bike one if interesed
think that even though not directly on the towball the weight of the rack plus the bike(s) will add to the nose loading - depends what they are towing with / towbar spec
So he's towing a large trailer and is not sure where to put his bikes?
The high wheel thing looks like a low of weight on the towbar.
My towbar carrier has a metal plate that is sandwiched between the ball bit and the chassis bit.
You just need longer bolts to put it on but once on, it stays there.
A pole goes into the plate thing and the bikes hang from it.
I don't use it any more so you can have it for £20 if you can collect. 3 bikes fit. It's a Witter one.
Wigan.
Just mount some roof bars to the trailer and do it that way. I've seen loads like that. 🙂
