Tow bar cost
[Closed] Tow bar cost
[#4443387]
Howdy
Just reading a current thread on rack options and I'm tempted to go down the towbar route - just bought a newish car and still a bit precious over it!
Anyone have any idea how much it costs to have a towbar fitted? Mate fiited one which was cheaper but a huge pain in the arse.
Also, anyone heard anything of Aiston racks?
Cheers in advance
Posted : 09/10/2012 8:20 pm
I just got a swan neck Thule bar with 13 pin fitted for 240. got it done when I bought the car.
Posted : 09/10/2012 8:24 pm
Circa £350
Posted : 09/10/2012 8:29 pm
What model number is that please?
Recommended?
Seems pricey initially but I suppose it's a good option if keeping the car in top nick is also a priority...
Posted : 09/10/2012 8:30 pm
180 with electrics (focus). Took some haggling on phone first!
Posted : 09/10/2012 8:31 pm
Depends on car model - my Focus cost 130 for tow bar and electrics at a place near Bradford.
As a ball park I would say about 200-250 would be about right fitted, i have paid 450 beforebutthat was for a Westfalia removeable towbar on a Pathfinder , on the other hand I paid 40 quid for a used freelander one and fitted it myself
Posted : 09/10/2012 8:37 pm
£240 , nissan primera
Posted : 09/10/2012 8:38 pm
Paid around £160 for a witter towbar, fitted plus electrics (Toyota Corolla)
Posted : 09/10/2012 8:41 pm
Jesus!
I was thinking £100-ish.
In that case...can anyone recommend a good all-round non-bankruptcy-inducing solution? 😯
Posted : 09/10/2012 8:43 pm
£215 for a fixed one on e90 BMW 3 series
£360 for a removable
From indedpension
They very wildly in price but one thing I would look into is how the electrics are fitted. Modern cars have a lot of multiplexed circuits and a badly wired unit may affect these. personally I had the correct loom fitted that plugs into the existing connector-if available on your car-so that no wires were cut or Scotchlok type connectors used.
Cost a king's ransom for a Witter detachable with full 13 pin electrics & 12v feed for the caravan fridge on my CRV 🙁
Posted : 10/10/2012 9:27 am
Sounds like a detachable is important if you have reverse parking sensors? Constant false warnings could get very annoying!
Edit: I see Witter let you put in your registration to whittle down the list of compatible towbars. Still expensive though! £433 up to £546 🙁
Posted : 10/10/2012 9:31 am
£250 for my previous car. £600 with the correct electrical connections (no error messages inside and links up to towing stability function) for detachable one. Quite a bit of that was just the cost of the loom. Also less than a third of what the main dealer wanted.
Posted : 10/10/2012 9:50 am
£40 for second hand tow bar and I fitted it myself
IMHO about an hours work in a garage 1 hr 30 max
Posted : 10/10/2012 10:09 am
If your happy to fit your own you can get the tow bar kit for around £75 ish and electrics kit for around £25 ish from [url= http://www.just-tow.co.uk ]here[/url]. Takes about an hour and not particularly hard but you will need to remove the bumper and rear lights to install. Apparently the Witter ones are slightly easier to install but I guess you get what you pay for
Posted : 10/10/2012 10:12 am
 timc
Westfalia Removeable towbar supplied & fitted for approx £300 by a towbar place in wigan pier called 'atlas' (I think) a friend recommended. Great service & great guys
Posted : 10/10/2012 10:50 am
most modern cars use cambus electrics including lighting circuits which makes it more exspensive to fit the electrics side
Posted : 10/10/2012 11:05 am
