Anyone know if it is possible to ride the BW through the forest above Torver on the way to Stephenson ground, heard there was logging storm damage awhile ago, best to avoid?
Did it on 7 August, you do have to miss out a couple of sections through the forest. You can still make it round the fire roads and do a couple of good sections, but I would've found it tricky to navigate had I not been with someone who knew the way! It all looked unfamiliar because of the damage and logging. Don't be put off though, you can still make it through. It might all be sorted by now.
As above, some rideable bits, some felled bits. It wasn’t horrific
T'was fine the other week. Just the last bit before you hit the road @ Stephenson grounds has trees across it but you can take a slight diversion onto the road.
This is the ride I did, not sure if you can work out the way through from this
https://www.strava.com/activities/7596664143
