Torridon area route...
[Closed] Torridon area route question
[#10981751]
Hi all , I've been to Torridon a few times and done the usual routes but I was wondering if you ride along the side of Loch Damh at the southern end you turn left where there is about a mile of road that's been built and then go over the tops and descend back to Torridon , the classic route if you like . If instead of taking the left turn you went over the bridge and followed the track south until Glasnock . Then there is a trail marked on the OS map that joins the A896 at Tullich . Is that a decent track to ride because then you could go down the road to Coulags and take the classic trail back to Torridon . I have never seen this route mentioned so I assume that the track from Glasnock to Tullich is not too good , but if it is it would make a decent loop .
Posted : 29/12/2019 2:55 pm
