Torque reccomendati...
[Closed] Torque reccomendation on carbon post?
[#5181786]
Hi,
Slipping carbon post.I have put carbon paste on but just wondered an idea of torque rating? Syntace post on Anthem X 29 if that's a help.
Thanx,
Max
Posted : 22/05/2013 10:15 pm
This should get you started:
http://www.bikeradar.com/forums/viewtopic.php?p=17215911
btw: probably less tight than you think if you've got the "sand in the vaseline" paste stuff in there.
Posted : 22/05/2013 10:20 pm
5.5nm on the fancy Giant road clamps but they are 2x4mm bolts.
Not 100% on the Anthem. Isn't it etched onto the clamp?
Drop me an email and I'll find out on Friday for you.
Tim
(part time Giant shop mechanic)
Posted : 22/05/2013 10:45 pm
Hi,
Thanks for that! I must stress I having been using carbon paste and still slipping! Didn't want to go too tight!
Probably slipping due to removing post for maintenance from time to time.
Thanx,
Max
Posted : 22/05/2013 10:48 pm
Hi,
Current clamp is a Thomson but that says 2.5 NM.Tried that and still moves.My old Fizik post had a figure of 6NM,not sure if that's too high.When it has slipped have used hand pressure which is probably more than 6NM?
Thanx,
Max
Posted : 22/05/2013 10:53 pm
6nm sounds about right for a single clamp.
Will check tomorrow for sure.
Tim
Posted : 23/05/2013 7:06 pm
Hi,
Thanks for the help and replys,
Max
Posted : 23/05/2013 7:10 pm
 IanW
Mine says 6nm, it was slipping new post in new frame, used the finish line stuff and bingo problem solved.
Posted : 23/05/2013 7:18 pm
6nm on mine too
Posted : 23/05/2013 8:23 pm
